  • Replies 612
  • 3 weeks later...
radio head -house of cards
video clip is cool
In Radiohead's new video for "House of Cards", no cameras or lights were used. Instead, 3D plotting technologies collected information about the shapes and relative distances of objects. The video was created entirely with visualizations of that data.
Ministry Of Sound 2008 Annual
2 reasons,
a) coz it is awesome
b) because it is helping to purge some of the rampant boganism Bard seems to be spreading about the place :D
wait till you hear the Ultra Beatdown tracks, listening to 'The fire still burns' right now :P
It sounds the same as the rest of their albums ooooooooooooooooooooooooooooooo :blink: There coming later this year cant remember the date
Digging the new slipknot song pshycosocial, cant wait til october when they come, going to get messy! might not come back alive
Edited by Dani Boi
It sounds the same as the rest of their albums ooooooooooooooooooooooooooooooo :P There coming later this year cant remember the date
DF are coming 22nd October... picked up my tickets today.
Slipknot are coming? awesome...
...and Disturbed in October too I just saw..... October is going to be very busy :blink:
  • 4 weeks later...
one one-slipknot
the virus of life-slipknot
resurection-chimaira
the flame-chimaira
driving down the darkness-devildriver
awoken-heaven shall burn
endzeit-heaven shall burn
LOS-RAMMSTEIN
hilf mir-rammstein
just my playlist for the train to work(Y) (Y)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
