  • Replies 612
  • 3 weeks later...
radio head -house of cards
video clip is cool
In Radiohead's new video for "House of Cards", no cameras or lights were used. Instead, 3D plotting technologies collected information about the shapes and relative distances of objects. The video was created entirely with visualizations of that data.
Ministry Of Sound 2008 Annual
2 reasons,
a) coz it is awesome
b) because it is helping to purge some of the rampant boganism Bard seems to be spreading about the place :D
wait till you hear the Ultra Beatdown tracks, listening to 'The fire still burns' right now :P
It sounds the same as the rest of their albums ooooooooooooooooooooooooooooooo :blink: There coming later this year cant remember the date
Digging the new slipknot song pshycosocial, cant wait til october when they come, going to get messy! might not come back alive
Edited by Dani Boi
It sounds the same as the rest of their albums ooooooooooooooooooooooooooooooo :P There coming later this year cant remember the date
DF are coming 22nd October... picked up my tickets today.
Slipknot are coming? awesome...
...and Disturbed in October too I just saw..... October is going to be very busy :blink:
  • 4 weeks later...
one one-slipknot
the virus of life-slipknot
resurection-chimaira
the flame-chimaira
driving down the darkness-devildriver
awoken-heaven shall burn
endzeit-heaven shall burn
LOS-RAMMSTEIN
hilf mir-rammstein
just my playlist for the train to work(Y) (Y)
