Hey guys,
I just bought a Blitz Racing electrical Oil Pressure Gauge second hand, but it did not come with the wiring diagram, so im a little stuck. The wiring to the sender is all A-ok, its just trying to sort out what the wires from the back of the gauge. There is the following:
Red:
Black: (earth im guessing)
Blue: Warning light wire (dont know what this would tie into)
Orange:
Yellow:
If anyone has this gauge and knows what wires are what, or knows where to get the wiring diagram, it would be a great help. I have searched the net and googled everything i could think of, as well as going to the blitz website, but i havent had any luck so far.
Thanks for your help peoples.
Tony
Edited by SLVR32GTR
https://www.sau.com.au/forums/topic/145246-blitz-oil-pressure-gauge/
i couldnt find your model in the blits website....
heres the link...
http://www.blitz.co.jp/products/products.htm#01
use the google language tools if u want to translate any website or any words in jap to english....
in pdf...just highlight & copy from the pdf to the google language tools and translate them....
its as easy as that..
And if you can't translate it try hooking the different wires up to a household battery (probably one of those big square ones) this will establish which two are for illumination. Red is power black is earth and the other wire will be oil pressure signal.
If don’t want go hacking into the wiring harness near the cpu, just take your dash out and tap into the factory oil pressure gauge wire. Then hook the two illumination wires up to the lights to the cigarette lighter or the dimmer ((which goes to the dash (it will be the really dodgy looking wiring because all importers are really dodgy)). Then final just hook the red and black up to constant power like the factory clock or something.
Hope this helps.
Hey guys thanks for your replies.
Just to clarify, all the wires for the oil pressure sensor are separate to these 5 wires. So that means i have two wires that i cant figure out what they are for!!
Obviously there will be power, earth, and illumination. But what else could there be? The gauge has a warning light, but im sure that would also just run off the power wire.
Anyone with a Blitz gauge or instructions would be a life saver!!
hey bud i have that gauge and three other blitzs gauges exactly like that...im not entirely sure cos i havent looked at the wiring for ages i could take a look at it on the weekend for you..im pretty sure the yellow is for when u turn your head lights on either orange or blue do just the red needle (i think) and then i think the orange is for the warning light but unsure where it goes.....ill just have a look at mine over the weekend for you
Cheers mate,
I really appreciate it!!! Look forward to hearing from you after the weekend!
Tony
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
