Hey dudes....
I am currently running:
6.5 in jaycar audio response 3 way splits in the front wid crossovers and they are amped
they are 100rms... I have a 4 x 130 watt rms amp .. so running 2 channels to these speakers at about 3/4 gain.. so theyre getting about 90 rms or something..
I am planning on doing a sub install such as 2 x 12 inch subwoofers.
I am truly after clarity and awesome quality here...
the response splits crank and dont destort...
i am thinking getting 6" speakers for the rears prob 2 way 6 in Alpine Type R's....
what do you guys think?
after sound quality / loudness / no distortion.
cheers guys
ps i aint got 800 for speakers so no one mention like focal k2s lol.
I would look at teh depth of the alpines- they me hit the battery on the passenger side as the are DEEEP!
yeh nah they should b sweet... i had type s 6 inchers in my last car and i can raise them... its not the install thats the hard part.. just need to know what you reccomend.
