User:DR1FT3R
Car: R33 GTST 2door coupe series 1
Front Seats:no
Rear Seats:yes - Colour: Black, with red double stitching.
Wrinkle Front:no
Wrinkle Back:no
Logo Embossing Front:no
Logo Embossing Back:no
Handbrake Boots:no
Gear Stick Boots:no
Door Trims:no
Postage or Pickup:postage
Money Required: $150
Cheers,
Joe
Edited by dr1ft3r
  • Replies 562
Posted Images
Hi Jetdat,
Have you got anymore pics of GTR32? I really want to get a package, but I am not sure what combination is good, so more pics will be good.
Or can you give me the address of Ultimate Auto Trim? So I can go down and have a look.
cheers,
Could we still get the same deal with 12 order ? Jetdat, could you try and talk to united with that ? You can tell them that there were 20 orders previously and with this other 12 I can't see why they can't give us the same offer.
yeah man i think thats a fair call, lets get this thing going
These are the confirmations i got so far from ultimate.
>1) 08/12/2006 NETBANK TFR
> theevilworld civ06
> $630.00
>2) 01/12/2006 NETBANK TFR
> theevilworld r33gt
> $630.00
>3) 01/12/2006 NETBANK TFR
> anDru Leatherette
> $630.00
>4) 01/12/2006 BENDIGO BANK
> OL_MATE R33 S2GTST
> $530.00
>5) 30/11/2006 NETBANK TFR
> uLa32 GTR32
> $600.00
I'm about to place my order, but would like to know:
(1) Where are the seat covers made?
(2) How long should I realistically allow before I receive the order? 4 weeks? 6 weeks?
Ta
its been like 6 weeks already lol......when does the actual 4 weeks start countin. jetdat man lets get this moving if u feel like the others are wasting our time
not sure where the covers are made...
Are they made by Ultimate Auto Trim in Dandenong, Vic?
The reason i ask, is if they are made overseas i am reluctant to buy them in case something goes wrong - but if they are Aust made, i will get a set.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
