User:DR1FT3R
Car: R33 GTST 2door coupe series 1
Front Seats:no
Rear Seats:yes - Colour: Black, with red double stitching.
Wrinkle Front:no
Wrinkle Back:no
Logo Embossing Front:no
Logo Embossing Back:no
Handbrake Boots:no
Gear Stick Boots:no
Door Trims:no
Postage or Pickup:postage
Money Required: $150
Cheers,
Joe
Edited by dr1ft3r
  • Replies 562
Posted Images
Hi Jetdat,
Have you got anymore pics of GTR32? I really want to get a package, but I am not sure what combination is good, so more pics will be good.
Or can you give me the address of Ultimate Auto Trim? So I can go down and have a look.
cheers,
Could we still get the same deal with 12 order ? Jetdat, could you try and talk to united with that ? You can tell them that there were 20 orders previously and with this other 12 I can't see why they can't give us the same offer.
yeah man i think thats a fair call, lets get this thing going
These are the confirmations i got so far from ultimate.
>1) 08/12/2006 NETBANK TFR
> theevilworld civ06
> $630.00
>2) 01/12/2006 NETBANK TFR
> theevilworld r33gt
> $630.00
>3) 01/12/2006 NETBANK TFR
> anDru Leatherette
> $630.00
>4) 01/12/2006 BENDIGO BANK
> OL_MATE R33 S2GTST
> $530.00
>5) 30/11/2006 NETBANK TFR
> uLa32 GTR32
> $600.00
I'm about to place my order, but would like to know:
(1) Where are the seat covers made?
(2) How long should I realistically allow before I receive the order? 4 weeks? 6 weeks?
Ta
its been like 6 weeks already lol......when does the actual 4 weeks start countin. jetdat man lets get this moving if u feel like the others are wasting our time
not sure where the covers are made...
Are they made by Ultimate Auto Trim in Dandenong, Vic?
The reason i ask, is if they are made overseas i am reluctant to buy them in case something goes wrong - but if they are Aust made, i will get a set.
    • R32 HICAS, so long as the CU is not itself faulty, is easy to keep working enough for the PS. Just unplug the smaller of the two loom plugs, on the CU, like I have already said about 4000 times on this forum. This works with all the stock hardware, or with a lock bar, or with a complete removal. I know, because I have done all of them. OK, actually, I never put a lock bar on because why would you put a lock bar on when you can get rid of the whole lot, including the stupid tie rod ends?
    • Join the NorCal facebook group btw, but if you can confirm it is HICAS I would install a lock bar and do the work to keep the HICAS control unit happy despite the hardware not functioning. The HICAS control unit is also responsible for speed sensitive power steering so if it's unhappy you'll get failsafe/heavy power steering. A standalone can control that power steering solenoid valve but sometimes it's just easier to stick with the factory setup. Tomei makes a little electronic module that you can install to fool the control unit. I would probably go through the effort to not use a scotch-lok and build a harness so I don't have to chop up the OEM harness. Where you could source those connectors and pins I wouldn't know at the moment though.
    • Oh, another question comes to mind though. What sort of shitty fuel are you feeding it. Mine, a turbo, has to be fed 98RON, so it doesn't ping itself to death. 98 in Oz is good, dense fuel with minimal oxygenated compounds. Meaning that the energy density is high, and if the O2 trim is working, you will get more MPG than with a lesser fuel. If you're using some sort of piss poor E10 blend with some other MBTE or other oxygenated additions, that could explain using more per mile.
    • I have no idea where the thump is coming from, it sounds like its from behind me but im not exactly sure. And it was the HICAS light that came on.   I think a complete delete is the route im going to go. Probably going to pick up the kit within the next month and get it installed. HICAS is just going to end up being a headache if I keep it.    Thanks you.
    • Just putting this here for reference for other beginners. Similar to what I said above.  I learnt if you have a few dents that are fairly close to each other (within a couple of inches maybe 2-4 inches?) Use filler across them all and sand it all at once with the long block as opposed to fixing them seperately.  Will make life MUCH easier because you won't get stuck in the cycle that I did. I think doing it seperately there is some overlap (mean your whole repair zone might cover near the area of the other dent) and you start sanding near the other dent making a low spot.
