I so want in..
Before Im in Im Thinking either of these two setups..
R34 GTT Coupe 1998.. Black .. help me out here..
Black seats, Red stitching with red middle bits or ..
Black seats, Black stitching with cream/tan middle bits?
I like red but im afraid that if I get it on the interior panels such as the shifter and hand brake its going to be really bright .. Anyone got a pic of it?
  • Replies 562
Posted Images
hi, i really would like to place an order but don't no the colour codes for the leather. have looked for about an hour and still cant find any thing that can tell me what colour has what colour code.
can some one tell me what colour = code and which ones are wrinkle and non wrinkle?
moo1 = black...
m002 = ...
m003 = blue
m004 = dark grey?
and so on...
any help would be much appreciated.
thanks, loren
same here I need red door trims hand breaks and gearshift boots and the middle glove bcx cover for GTT ...same red tone as bride seats..dunno colour code
I so want in..
I'm in the same boat mate. I'm thinking two tone black with red double stitching.
A dark black outside with lighter black inside. I was thinking about a copy of the OEM seats but I saw some black leather GTR seats and they were HOT!
PACKAGE DEAL!
User: DECIM8
Car: SKYLINE R34 GTT COUPE 1998 - JUST WANT OEM STYLE
Front & Back Seats: BLACK - M001 (MAIN COLOUR [outside]), RED - M002 (SECONDARY COLOUR [inside])
PLEASE LEAVE HEADRESTS AS MAIN COLOUR M001
DOUBLE STITCHING IN EVERYTHING IN RED - m002
Wrinkle Front & Back: NO!!
Embossing Front & Back: Possable to get the skyline "S" embossed? in all seats
Door Trim, Centre Console, Handbrake Cover & Parcel Shelf, Gear Boot in: M002
Postage: Yes - NSW
DO NOT WANT: DO NOT WANT HEADRESTS IN m002 ONLY IN M001 - Rest of seat per normal
Thank you! Please let me know!
Edited by DECIM8
The group-buy administrator should set a firm deadline for payment, and a closing date for this group buy, and that way all 20 people will know when payment MUST be transferred, or they miss out. This will get things moving fast...
What if the call went out for payment by the due date or your out. Then see how many people there are, you should be able to negotiate with the supplier to see if they will honour the offer with slightly less orders.
The alternative is that we sit here doing nothing for another month, and then even after the order is put through I believe it is not a short process to have the covers made.
when fitting these seat covers, can you ever remove them . by the looks of these pics it seems that u gotta put holes in ur seat to push the ties through to hold it in place, or is it all just done from underneath .
also any word if he has purple ?
i think i speak for everyone jedat when i say can we have a list of ppl who have paid and a list of ppl who havnt......so we can see how many more ppl we need and which one of those are holding us up
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
