the amount of money you'd waste doing that, you could almost sell your GTS-t and buy a proper GTR
agreed, or rip the engine out, sell it and put in a standard rb26, it will still be faster not to mention more reliable.
Edited by 33NIZ
I would opt to go either gtr engine or simply upgrade single turbo, fuel, injectors and intercooler. i was gonna tt the rb25det and every performance store i went to basically told me to piss off and not waist there time
Having had one of the first Twin Turbo rb25’s in Australia, Queensland atleast it’s not really worth it.
What’s the goal for the car? Street? Drag? Drift?
Rb20’s aren’t really ideal straight out of the box as well; do you plain on running a stroker of any form? Cost Vs cost it's cheaper, easier and a better out come to just upgrade to a bigger single + support gear.
But hey, if you wana be a bit different, why not, one of the guys on Secret drift had a Twin Turbo rb20 in his Laurel, was meant to be pretty responsive, only made about 220rwkw though I believe..
From memory man it was a lag monster. Didnt come on to boost til 4500 or something. And they werent massive turbos either. But that is just from memory.
I think you maybe right, can't really remeber the car or the specs too well.
I saw at Goodyear underwood a s13 RB20 Twinturbo being built. If you ring you want Luke the mechanic.
I would agree with the posts above stating that it would be a waste of time. If you have the money and time to pour into it for a drift or drag car then go for it. other than that it would just be more of a dilemma than a dream to drive.
Good luck man--- GO RB26!
If it really comes down to it tho an RB25 in an R32 is going to go pretty darn good. Sure the RB26 is good braging rights, but bang for buck its still way off.
Really, work out what you want out of the car before you make up your mind. But if you got enought to be even thinking about twinning an RB20, you should be looking seriously at other options.
seen up to around 280 - 300rwkw on a BIG budget 20
I've seen quite a few with 220-240rwkw with fairly modest budgets, but how long they will last is a good question. That said anything over that and your looking for some rebuild stuff to keep it reliable. That and headwork...
would be interesting to see what is acheivable, but logically thinking the RB20 is only a 2.0L motor and u are putting twin turbos set up off an engine which has an extra 0.6L ontop iof it, which i reckon would put you behind the ball from the get go, not enough capacity to sustain the set up and will be a lag monster one would think.
RB25's are a popular conversion into R32's nowdays, they are bigger capacity motor and are apparently a bit stronger then the RB20 in stock form. plus not to mention they are a newer motor, failing that id go the RB26 if u can find a decent one about. butu u gota think of things like if u break the 25 its wont cost as much to replace as the 26, and or rebuild.
I did it doing all the labour and fabrication myself. Have about $3K spare to do it yourself. $5K-7K if you were to pay a workshop. Standard gaskets are expensive, about $400. Another $400 for lines, all the twin exhaust setup fits but the manifolds need to be cut and welded and match ported or an adaptor plate fabricated (part of this revision), fabricate a single AFM intake for the turbos, oil returns are a pig, the list goes on.
My goal was TT on a higher compression well built race engine, so I had a logical reason, and now done I'll stick with what I'm doing but not worth it just for bragging rights. I'm still contemplating a decent single and good manifold and selling the "kit" but still running the six throttles.
I am in the process of checking over the engine and fitting different turbos, new injectors, GTR throttles and intake and the adaptor for the exhaust manifolds so hope to be running again in about 4 weeks. Didn't get much time to try it as there was a problem with the injectors it seems. With a stuffed back I have been unable to do the pull down.
Spot on! When I bought my RB25 R32 it was great! It was making 200rwkw and was pretty quick...now it makes 245rwkw and it is nuts! I love it
I bought a whole forged, rebuilt RB25 with 4000km on it for 5k and last time I looked an average RB26 is going to cost that much at least! SO bang for buck the RB25 is the hands down winner
so ultimately a rb25 would require less $$$ spent on it to aquire similar power output of a rb20?!!
around 200 rwkw is easy for an RB25 whereas an RB20 will need a turbo swap before then, also the RB25 will have better average power even if the RB20 makes a similar peak figure
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
