Hey people,
According to the latest SEVS rulings, the four-door R-32 is still eligible for import...:P
Does anyone know who may have gone to the trouble and expense of getting SEVS/RAWS compliance rights for these cars? I've recently been told that someone is interested in buying my car off me, so I think if I can scratch and scrape some money together it may be time to bite the bullet and get my dream car (or at least one on my very long list).
Any help and/or pointing in the right direction would be greatly appreciated!!!
Cheers,
Nick T
https://www.sau.com.au/forums/topic/14545-r-32-four-doors/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
