I just took my r33 gtst out for a spin (the temperature here is about 40 degrees C) and it was running really rough, backfiring lots and stalling quite often. Could rev it while idling in neutral and the thing would just stall when u back off. The engine was surging a bit as well. It was running fine when I was driving it the night before.
Does anybody elses car run rough on hot days?
i have an r32 in the heat it sometimes idle's a little wild like jumps up to 2,000rpm and drops or idles high, but i usally let it sit for a while and it sorts it self out,
maybe in your case the your tunes not up to the hot weather?
do you have standard ecuor aftermarket??
i have a series 2 r33 and i was almost beaten by a vn commodore the other day when it was about 32degrees. i was disgusted. however im 95% sure this is because i have a pod filter on my car and it sucks in alot of hot air from the engine. im looking at getting some piping and mounting it to the front bar soon. but overall yes my car does run worse in the heat. i love driving on a nice cool night. so does the car!
I have the same problem. Yesterday and today the temps have been 38 and 41 and since yesterday when I went to start my car, that had been sitting out in the sun for about 4-5hrs, the car would idle at 700-800rpm but then drop down very low (100rpm) and then try to raise up again to 700rpm. Sometimes it would not raise the revs and just stall. If I start the car up and give it a little gas to raise the revs up to 1500-2000rpm for a bit the car settles down and drives normally. Has the heat damaged something in my car?
Thanks for the response MintR33. The idle problem only seems to happen when I start the car up after driving it for a while so the engine is still warm (or hot as the case has been the last couple of days with the weather in Adelaide!), I don't have the a/c on at this stage. Once the car has been driven for a short while the car idles normally at the lights even with the a/c on. I have just had the cooling system and a/c system fixed with all new parts, but the car was fine after all that work. It has only started with the extremely hot weather.
mine does the same, hell a barina sri kept up with my r33 gtst on a 40degree day.....i was like wtf?
i believe that if you have a pod filter shield it off, do whatever you can to get colder air in and should be a bit better. but yeah turbos sucking in hot air does't exactly make performance increase..
  • 4 weeks later...
It's not like I'm asking my car to do anything special. I'm not even wanting the car to perform well in 40 degrees just wanting it to idle normally and not stall.
I take it that others whose car has had idle issues in hot weather haven't been able to fix this problem?
Its not about performance in hot weather but as to why his car is basically not drivable in hot weather.
yeh, my car is a piece of shit in the hot weather...much slower
mine just feels like it has a little less power, apart from that the idle and everything else is fine in hot weather
...... do i need to point anything out further?
the post where i stated " its common sense turbo cars wont perform in hot weather " was directed towards them posts. and clearly... them posts are stating they are giving there car shit in hot weather and the cars not performing like they are used to in colder weather. i hope to god i dont have to explain WHY this is so...
Well im sure you could add something more constructive towards the issue that "understated" is having other then "yeah lets all go flog our turbo cars in 30-40 degree weather. realllll smart"
He isnt talking about flogging his car in the heat even if that seems to be where rochey took this thread in his battle against a vn commodore.
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
