R34 Gt-r Front Diffuser/front Lower Lip + Rear Bumper Lower Skirts
Contact this guy, his name is Daniel...lives at Helensvale. He has 2 x GTR guards in bayside blue + front bar, they should still be in as-new condition. They were thrown in for free with his R34 he bought (which he is now selling) so didn't use the parts. As far as I know he's still got a damaged carbon bonnet off a NUR spec.
Mobile Phone 0410641317
Home Phone 07 55560207
Work Phone 07 39084308
Hey champ they cost about $1100 brand new from nissan. mine is f**ked also so i think i will be buying one soon
Thanks for that.
Thats my problem. $1100 for brand new and i know i'll screw it up most definitly.
My lip is already low enough, not worth $1100 and destroying it within a month.
Thanks for the info, GTR Guards, Front Bar, Carbon Bonnet?
No Front Diffuser?
Sorry, have i missed something?
I'm looking for the Front Lower Lip/Diffuser.
Cheers
Not all that much. Reasonable price though.
I can get them brand new but just not worth it.
What have you got to offer or do you know someone who has something to offer?
I have one on my car but it spends most of the time off the car i may part with it for around the $500 mark it is in good condtion compared to some i have seen has a couple of scratches on one side
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
