TCS = Traction Control
It's the button just above your left knee when sitting in the drivers seat.
Putting it simply; TCS is a safety system that detects when the front wheels are not spinning at the same speed as the rear wheels (in such instance it cuts the fuel/ignition making you lose power/momentum)
Turning this off enables you to drive a little differently without the car cutting out on you (e.g. burnouts, drifting, violent gear shifting...)
• Awesome for the track, no need to remember to press 'that' button
• Mismatched rims sizes (people who put R34 GTR rims on and find the TCS triggers)
• Upgraded valve bodies, hassle free driving without TCS kicking in every gearshift
• Manuals, chirp gears without losing power between shifts and boost dropping off
Now available on e-bay, tell you friends search for 'R34 Skyline TCS'
I'll discount the price for any friends of SAU members, they pay the same as you guys and not the advertised $35.
while leaving the throttle wide open and actually leaning out the engine.. bit like a rev limiter.
Kind of, it actually drops fuel from 3 cylinders as well as closing the second throttle, turns the car into a 3 cylinder for a second or so.
I got mine on Friday. Simple and quickly installed.
Works a treat. Start the car and BAM! TCS is off. No more fiddling for the switch as you approach interesting corners bends or taking off at the lights. I can finally sleep better knowing that the car isnt going to want to go limp on impulse.
:laugh:
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
