time to sell the beast..just started a new app and cant afford to treat the baby like i shuld be. hoping to sell it to anutha line lover so i no it will have the care desired hahaha
heres the details guys...
PRICE: 15k ono (consider ANY offer)
car: r33gtst coupe
colour: silver/grey
engine: rb25det
manual
k's: bout 120
other: atm the car is un-registered, front left wheel hit a gutter bout 2 months back. lower control arm needs replacing (which i will prior to sale) and i figured i'd wait to get the roady and rego when a buyer comes up.. just so they get full 12 months.. which means rwc and 12months rego will be supplied with purchase
it has a custom veilside widebody, minus the front bar (series 1) done by xxx. appeared in autosalon 06.
mods:
-front mount
-bov
-3.5 inch turboback exhaust
-5inch tip
-hi flow cat
-boosted 12psi
-pillar gauges
-18inch deep dish rims
-comes with plenty of standard spare parts, including wheels
location and contact;
rowville vic, 3178 ... 97529233,... 0400117463
https://www.sau.com.au/forums/topic/145726-widebody-33-gtst/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
