  • Replies 88
Originally posted by Works Auto
When i had my stock turbo and i put a Hybrid front mount on, trust me when i say "it didnt go slower "
It picked up alot of power.
rev210 i think thats total rubbish and i duno how you can back up your claim. The cooler the air, the denser the charge = power.
Yes the colder the air, the denser the charge = power is true. But , the longer the pipe and the greater the volume to fill, the longer the time taken to reach piston = slower engine response time (note I did not say anything about lag).
Turn your hose on and see much longer it takes to fill a 15L bucket Vs a 2L one at the same hose pressure, thats the difference in volume between the GTR cooler and the stock gtst one from memory. Sure the air is colder and the engine makes more power, it just loses time in getting to the same rpm.
If you'd like to tell me how making the air path 'longer' increases performance I'd be interested to know too.
I don't think you are suggesting that making the intercooler pipes do two laps around the car body would help. The principle is the same on the larger volume intercooler although the magnitude is less ridiculous.
You may be missing my point. The 'power' over a stock unit I have never disputed. My issue is the possible response time issue introduced by the greatly increased volume of the new intercooler and piping.
Here's how I back up my claim alternatively :
Let's see a front mount intercooler equiped R33 gtst with a stock turbo run better than a 13.3 @106mph on 205's. To the best of my knowledge there isn't one.
I'm not trying to poo poo aftermarket intercoolers, I'm very sure that you can do much better than the stock unit, it's just that for the extra expense you need to make sure the size is 'just right'.
Someone should do some calc's.
We need to work out how much extra volume a FMIC (including pipework) has over a stock one.
Say if it's an extra 20lt, then we can work out how much longer a 2.5ly motor will take to fill the space.
Say at 6000rpm and 2500rpm (where people change gears, and the rough spool up area for a turbo - this is rough).
The motor will push out 2.5lt of air for every four rotations. So at 6000rpm the motor is pushing out 2.5lt of air 1500 times a minute, so that's now 3750lt of air every mintue.
So now we need to find out how much time it'll take the motor to fill this extra 20lt of space, when the motor flows 3750lt per minute.
Am I thinking on the right path here?
OK - my brain just reached it's limit (I'm on holidays and my brain is in life-support mode).
Jay95R33,
I think sydneykid did some calcs some time back on the same subject.
I say this thread should be moved to the forced induction section to allow more participation in the debate.
zanda,
if he has that time at the plex and not a g-tech then I conceed he has a better time and for the time being a faster car, he probably even did his pass on 165 tyres :) I guess that just leaves me with the fact that I haven't blown the best part of $1.5K on an intercooler to go 0.1sec faster (he is still faster so I'll have to suck eggs).
    • This is the GTR fuel pump. Yellow shows 12V, orange shows earth. The ECU provides the earth to activate the fuel pump relay. The ECU side of teh relay will pull low when the ECU activates. This is the RB20 fuel pump. Almost the same, but a little simpler. You can see I indicated (above) where the 12V line goes down to the RB20 diagram on the overall diagram, whch shows both RB26 and RB20. This is where I show it coming in on the RB20 diagram below. You can see that the dropping resistor is handled differently. When the fuel pump control is not providing earth to the pump, the pump earths through the dropping resistor and thus runs at lower voltage (some is wasted over the resistor) and runs slower. I showed that "not 12V and not quite earth" portion of the wiring in a paler orange. The rest of the wiring that I did not colour on that little section below the pump would be orange when the fuel pump coontroller is providing earth. This drop is handled inside the fuel pump controller in the GTR. Regardless, you can see where 12V is supposed to be, where earth is supposed to be. The key on prime is via the ECU providing the pump for only a few seconds the switching off. You should be able to see that happen.
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
    • They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox) They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox)
