went to wakefield park for a trackday today and it was friggin awesome.....the first time out in a RWD and i must say i havent had that much fun in a long long time.....the rain in the afternoon also helped as i got some dorifto practise :(
anyways, i managed to get a hold of my friend and personal photographer gavin from www.gavincato.com and here are some shots - thanks gav! ;)
https://www.sau.com.au/forums/topic/14651-my34-at-trackdaynot-dialup-friendly/
Franks, good to see you having fun man. I took my yellow Fellow out there as well when I had the GTT and it was an awesome day. Didn't get as good pics as you though...they are magazibe quality dude. Print them and enlarge for your office or study I say.
What camera was use to get STILLS like that? Looks pro.
thanks for the comments guys, yeah the shots were crazy nice. gav was only there for a coupla hours too! lucky the ones he took were of high quality!
hah, it seems that way doesnt it nissaner?! lol ... atleast someone picked up on the MY34 :( dunno why but that just seemed to be better than ER34 ;)
swoop, yeah i was a little hesitant to bring it out, but at the end of the day i was there to have some fun and maybe be not as competitive as the others. but i was running unofficial low 15's so i was happy considering they were street tyres and stock suspension....next time it should be different ;)
gav uses a Nikon D100 and the size of his lens was about as long as my arm. some really nice equipment so yeah, really really nice results...
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
