Well why ask the question then?
None of us really care if you decide to hack up your car to fit some 7x10's in. They've given you an opinion and you're not going to take any notice, so go do it your way.
Thats true.. i'm arguing here for someone that hasn't had barely any input to this topic.. screw this. 'Ol_Mate' thats the best post on this topic i've seen... :laugh:
As for if they fit or not... its going to be a bit of a hack but they will fit.... probably sound pretty good too...
come on guys no need to get all cut here.
i obviously asked because i'm clueless when it comes to audio and never fitted any kind of speakers myself in a car.
but after thinking about it and doing some searching last night on this forum on how to remove the parcel shelf i came a cross a DIY on how to make your own parcel shelf and thought it would be a good idea. i've already removed the rear seat and already have plenty of mdf boards and all the tools i need. plus i got absolutely nothing else to do so yeah...
i appreciate all the opinions given.
cheers
Edited by R-SPEC
no ones getting cut here man... just take out your seats, take out your shelf, buy some mdf wood and mark the outline of the shelf on the mdf, try with 18mm to make it thicker, cut it out then put it in the car and see if it fits, you might need to cut the shelf your making up just a tad where the window angles down but carpet covers EVERY screw up you make so dont be too fussy.
You will need to cut metal but you'll need the right tool for it so until you have that tool... i cant remember what its called but its something car audio fitters use thats on a 90 degree angle, i wouldn't really attempt it, but if your bored go for gold, once again they will fit so try your best and you will succeed. :ninja:
Edited by R33HVN
yeah like i said i already got the mdf and stuff. my dad's an electrical contracter so i've got access to all the tools i might need :ninja:
from what i read its not really hard to do except for the little tricky parts like you said on the window side and its a bit time consuming but i got all the time i need :P
i'm keeping in mind every suggestion given here just incase it doesn't work out so don't think i'm ignoring any opinions in this thread otherwise why would i have started it.
thanks
thanks
nah the only concern is cutting the metal everything else is a peice of piss... i made the shelf for my 6x9's in 20mins flat... cut out and carpeted and fit like a cok in a sok.. just worrie bout cutting the metal... where there is a will there is a way... and the 7x10's will fit
Closed.
R33HVN for someone whose been a member for a few weeks you need to adjust your attitude. You wanted him R-SPEC to consult a professional? frx026 & Chris Rogers are, and were providing their input as such.
R-SPEC: if you'd like the thread re-opened if you want to seek more advice or have any more questions, please let me know.
Cheers.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
