im in the process of getting moneis together so i can get bigger cams (not overly big) and valve springs to go with. :rofl: hopefully will get a nice amount of power then............so doesnt make the car seem like its "all show and no go"
not that i really care what people think on that topic
damn it sounds like ur real serious about pumping as much out of that NA as possible. have you ever thought of getting a turbO? not that theres anything wrong with ur NA, but the benefits would be alot more!!!
like i said though its a hot looking car.
yes i am quiets serious about keeping her n/a!!!!!!!
i do agree that yes the benefits of a turbo are there.........but i dont want to be like everyone else who has a turbo......
i have a plan that i am sticking too..........
do the cam shafts, valve springs, bearings too! aftermarket ecu
and see what happens! may end up being a rebuild!
  • 1 month later...
Hi guys, the weather was nice over the weekend so me and the missus took some shots in front of adelaide oval and the city east end.
Very nice mate. The stripe suits it well too. You've done the right thing with the caps as 34 wheels look feral without the centre caps on. I had a set of 34 GTT wheels on mine and they look very very tacky without them :blush:
Very nice mate. The stripe suits it well too. You've done the right thing with the caps as 34 wheels look feral without the centre caps on. I had a set of 34 GTT wheels on mine and they look very very tacky without them :)
Thanks mate, yeah caps stay on :) Unless it's like on an S14 or something or S15, it seems to go well with those cars without caps for some reason.
Hey Howie nice 34, Hey you have the GTR style rear bar dont you? Do u have ne idea if it would go with a impul kit? (impul front n sides with a GTR style rear bar) Cause yours seems to blend in nice
Cheers Tom, it's the factory option from the nismo catalogue, not quite GTR style. I've thought about getting just the impul front bar for the car, but wasn't sure about keeping the skirts, the rear though would probably look fine with it.
hey peoples my 34 is to leave Japan sometime this month i hope.....
anyway heres a few pics of it in Japan
very nice ride.love those rims.
hope you gona take that wing off....
please take that wing off.
Edited by fob2nv
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
