im in the process of getting moneis together so i can get bigger cams (not overly big) and valve springs to go with. :rofl: hopefully will get a nice amount of power then............so doesnt make the car seem like its "all show and no go"
not that i really care what people think on that topic
damn it sounds like ur real serious about pumping as much out of that NA as possible. have you ever thought of getting a turbO? not that theres anything wrong with ur NA, but the benefits would be alot more!!!
like i said though its a hot looking car.
yes i am quiets serious about keeping her n/a!!!!!!!
i do agree that yes the benefits of a turbo are there.........but i dont want to be like everyone else who has a turbo......
i have a plan that i am sticking too..........
do the cam shafts, valve springs, bearings too! aftermarket ecu
and see what happens! may end up being a rebuild!
  • 1 month later...
Hi guys, the weather was nice over the weekend so me and the missus took some shots in front of adelaide oval and the city east end.
Very nice mate. The stripe suits it well too. You've done the right thing with the caps as 34 wheels look feral without the centre caps on. I had a set of 34 GTT wheels on mine and they look very very tacky without them :blush:
Very nice mate. The stripe suits it well too. You've done the right thing with the caps as 34 wheels look feral without the centre caps on. I had a set of 34 GTT wheels on mine and they look very very tacky without them :)
Thanks mate, yeah caps stay on :) Unless it's like on an S14 or something or S15, it seems to go well with those cars without caps for some reason.
Hey Howie nice 34, Hey you have the GTR style rear bar dont you? Do u have ne idea if it would go with a impul kit? (impul front n sides with a GTR style rear bar) Cause yours seems to blend in nice
Cheers Tom, it's the factory option from the nismo catalogue, not quite GTR style. I've thought about getting just the impul front bar for the car, but wasn't sure about keeping the skirts, the rear though would probably look fine with it.
hey peoples my 34 is to leave Japan sometime this month i hope.....
anyway heres a few pics of it in Japan
very nice ride.love those rims.
hope you gona take that wing off....
please take that wing off.
Edited by fob2nv
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
