Near impossible to find original item... The guys at powerplay were telling me cause funny enough someone from perth emailed them with a pic of my car with my carmate copy version.
I've got the carmate.com copy version which fits ok but the person who installed it did it wrong so doesn't look as good as that one but still nice.. they cut the intercooler outake bit instead of cutting the front bar to fit around the "fin" as seen in last pic. See my pic attached for better explanation of what i mean lol.
oh lol i see what you mean lanky! wat a bummer
Yeh mines an original, makes the front bar look so different to stocko, yet its a simple lip! :)
You end up with two big holes in your front bar though with the original fitting nissan item, where these rubber bungs sit
lanky, your one runs up abit of the front vents, different to granthem's. His are moulded around
Yeh, lanky said his fitter was meant to cut around the intercooler vent into the lip but instead he cut the vent to fit the lip :teehee:
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
