new plates... I boost
Dont worry eyelids getting back on soon, along with spoiler coming off again
Good idea...
If only we could use 7 letters, I can think of plenty with 7.
Anyway, I also bought two custom plates back in May:
The 'WJ' were originally going onto the R34... but I liked the look of the Targa plates better :D
BTW - last time I checked, 'R34' was still available in Tassie.
I *nearly* ordered them but the Targa plates were half the price - and if I sell the R34, the plates would only suit another R34, so...
clean engine
well, had to take a wheel off today to check if it was leaking or if i drove over a nail cause my pump didn't work.
Didn't sound safe with the jack below it and i didn't want to take it any higher and place a stand below it so grabbed out a 18" SSR rim with 285 x 30 x 18 on it :D
There is a spacer in there.
I dont like the white on chrome.
Thoughts?
Edited by Owgasm
clean engine
Didn't sound safe with the jack below it and i didn't want to take it any higher and place a stand below it so grabbed out a 18" SSR rim with 285 x 30 x 18 on it :whistling:
Thoughts?
your R34 looks...wierd? should paint the bottom lip or something and clear front indicators. cause looks like the front is higher then the rest of the car.
id stick with the old rims, black chrome lip, and maybe some c/f ganador mirrors
Yeah, its a 33 :thumbsup:
But possibly cause its on a hill, so the rear is experiencing my force downards.
The front looks odd cause theres no lower lip, i reckon any GT-R 34 requires the lower lip/diffuser, else it looks funny.
I've been looking for years, believe me i've noticed.
But i wouldn't paint it anyways :P
I prefer the black and chrome lip. These others wouldn't fit anyways, the rears are 335's.
Edited by Owgasm
and bakes, I LOVE your garage, so clean and simple :thumbsup: very jealous
Thanks buddy. I painted it just before I picked up the GTR. My missus laughed at me when I said I was going to paint the garage red (was a dirty white color before) but it came up sweet!
Hi Bryn, it's just the flash.
Would be good if the doors had lights instead of reflectors though.
yeah i remember when i got the car in 05, i took them off thinking the bulbs had blown but couldnt find anything :(
when i saw urs i was like :O no way lol
when i saw urs i was like :D no way lol
Hehe :D
Yeah, I had much the same idea when I first got my 34 - I thought the bulbs had blown.
Ok, thought i'd post a couple of my pics of my GTT R34 ,, yes it is a GTS-R badge.
Top Secret GTR front bar and Z-Tune Bonnet
Sorry pics not best it was raining at the time.
thanks for looking, just needs the top secret front diffuser lip
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
