  • 3 weeks later...
Looks great.
For some reason I didn't really like the colour coded middle and lower diffuser. But for the black GTR, it seems necessary.
I wish my fake could run R34 side skirts, i've got the z-tune skirt and pods, but will just run the pods :(
Will save the skirts my real :)
Thanks Simon. Do you mean because it's black, it doesn't need to be colour-coded? Or especially because it's black, it should be colour-coded?
Here's a pic of my old R34 which had colour coding all the way to the bottom. Car is also for sale as it happens - make me an (reasonable) offer! :)
Sorry for the confusion. Personal opinion, in the case of your black car, the lips should be colour coded to suit better.
Your last picture at that angle is hard to see the lips, but i'll go check it out in the for sale section :)
Full conversion (front/rear) was done many moons ago. (02/03 - r34 GTRs were over 80-90k plus, in saying that, it was done at much less than anyone could imagine [only paint was done by someone else])
Justification wasnt necessary, I believe the challenge was where it started.
niiiiiice. had a look at it again after i posted, would be good to get metal guards instead of fibreglass, but ah well. don't have the money to drop on it at the moment.. would love to though. S1 R33 with LM-GT3's, R34GTR VSpecII frontend? AWW YEAH
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
