Still sitting too high, especially at the front but a huge improvement imo...
Along way to go to get it how i want but a very good start with these wheels!
Cheers,
Anthony
Looks awesome mate. I especially like this rear 3/4 shot. It will look sooo good with a 1" drop and front splitter.
Cheers guys..
Will be looking at getting some coilovers in the new year as my next mod, unless some good ones pop up before then...
Cheers,
Anthony
Happy new year mate.
post-86021-0-88652200-1323168218_thumb.jpg post-86021-0-62780400-1323168533_thumb.jpg post-86021-0-72345700-1323167638_thumb.jpg post-86021-0-73859100-1323168774_thumb.jpg
Edited by iwanta34gtr
Ha nice one buddy, looks alot better sitting properly like that! Not sure if I would still get it in my driveway at that height....
will have to fix the driveway ha.
Was just tossing up between clear or smoked side and front indicators, wonder if you can use your photo editing skills to see which one looks better if you get a chance?
Cheers,
Anthony
Merry Christmas Anthony...
Carrying on from iwanta34gtr's lead; I also added a V.spec splitter for you:
White lenses + splitter:
Smoked lenses + splitter:
I vote smoked. :)
Yeah Smoked does look better against the wheels...
Hey Matt can u put side skirts on it and rear pods?
And maybe even a set of Carbon Ganador Mirrors
Cheers matt, looks really good... wouldnt even know it was edited unless told i think!
When i was thinking about the smoked vs clear indicators, i wanted smoked, but i wasnt sure that they would come up dark enough to actually match in with the wheels, so was thinking the clear might be better to match the headlights...
thanks to your handy work though the smoked covers look awesome... I might ask for them for xmas haha!
Thanks again guys..
Cheers,
Anthony
Haha that'll cost $29.95... a bit more effort involved there! But do-able. Maybe if one of us gets bored enough we can give it a go.
Thanks again guys..
Cheers,
Anthony
No worries mate, I think the smoked will look the goods.
they are 19x10.5
both our R34's have these wheels fitted but one car has a +22 offset and the other is a +12
for more pics see our facebook page
http://www.facebook.com/profile.php?id=100002667275922&ref=tn_tnmn#!/profile.php?id=100002667275922
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
