We actually know another Steve, of Steve's Auto Barn at blackheath; he owns a BB with white LMGT4s and plates ORSUM. Great looking car, but been ages since Ive seen it.
Here it is!
And here's Chris's. Yeah it's nice. :)
Edited by God_speed
Maclarenf1, As promised. Only had two more pics -
Will have them one day once the engine side is sorted....
Silver LMGT4 looks really nice on a Black R34 GTR with Nismo Skirts and Spats with VS-2 bonnet. (not huge fan of the Nismo bonnet mind you)
This has being my inspiration for few years, which led to me buying my car... Not quite there yet !!!..
^ That looks very similar to God_Speed's car. Fantastic.
Maclarenf1, I'm assuming your car is black. Do you have any pics of it as is?
Pretty standard V-Spec [had a V-spec 2 badge, first thing to come off :) - hate fake badges] - had it for about 1.5 years now, ideally want to do around 1 track day maybe 3 month or so..once the engine is up to that, will think about the exterior...
Runs HKS-Fcon Vpro currently with Stage 1 mods (Only Turbo's to do - getting GT-SS / -9 at the end of the year and she is done)
Also came with some odd bits from japan too like 4 wheel drive controller, modified Diffs, heavy clutch, camber arms, oil cooler, NOT normal FINS on the rear diffuser and a mother of strut bar :)
Currently Runs 239.9 AWKW with 1 Bar + Cam gears on high and stock boost on Low (HKS EBC).
http://imageshack.us/photo/my-images/193/qldraceway.jpg/
http://img844.imageshack.us/img844/313/img1591n.jpg
http://img34.imageshack.us/img34/9316/img1554sd.jpg
Very Envious of you'r car - i am not very good in washing or buffing IMO...
http://imageshack.us...qldraceway.jpg/
http://img844.images...13/img1591n.jpg
http://img34.imagesh...6/img1554sd.jpg
Looks fantastic maclarenf1, thanks for sharing.
Thanks for the kind words. I'm no pro, but if you ever think I may be able to help with some buffing tips - just give me a yell.
M-spec inspired seats sound good, black leather i assume.
Very Nice!
...and some person is privileged to have both VS2 & R-Tune bonnets...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
