We actually know another Steve, of Steve's Auto Barn at blackheath; he owns a BB with white LMGT4s and plates ORSUM. Great looking car, but been ages since Ive seen it.
Here it is!
And here's Chris's. Yeah it's nice. :)
Edited by God_speed
Maclarenf1, As promised. Only had two more pics -
Will have them one day once the engine side is sorted....
Silver LMGT4 looks really nice on a Black R34 GTR with Nismo Skirts and Spats with VS-2 bonnet. (not huge fan of the Nismo bonnet mind you)
This has being my inspiration for few years, which led to me buying my car... Not quite there yet !!!..
^ That looks very similar to God_Speed's car. Fantastic.
Maclarenf1, I'm assuming your car is black. Do you have any pics of it as is?
Pretty standard V-Spec [had a V-spec 2 badge, first thing to come off :) - hate fake badges] - had it for about 1.5 years now, ideally want to do around 1 track day maybe 3 month or so..once the engine is up to that, will think about the exterior...
Runs HKS-Fcon Vpro currently with Stage 1 mods (Only Turbo's to do - getting GT-SS / -9 at the end of the year and she is done)
Also came with some odd bits from japan too like 4 wheel drive controller, modified Diffs, heavy clutch, camber arms, oil cooler, NOT normal FINS on the rear diffuser and a mother of strut bar :)
Currently Runs 239.9 AWKW with 1 Bar + Cam gears on high and stock boost on Low (HKS EBC).
http://imageshack.us/photo/my-images/193/qldraceway.jpg/
http://img844.imageshack.us/img844/313/img1591n.jpg
http://img34.imageshack.us/img34/9316/img1554sd.jpg
Very Envious of you'r car - i am not very good in washing or buffing IMO...
http://imageshack.us...qldraceway.jpg/
http://img844.images...13/img1591n.jpg
http://img34.imagesh...6/img1554sd.jpg
Looks fantastic maclarenf1, thanks for sharing.
Thanks for the kind words. I'm no pro, but if you ever think I may be able to help with some buffing tips - just give me a yell.
M-spec inspired seats sound good, black leather i assume.
Very Nice!
...and some person is privileged to have both VS2 & R-Tune bonnets...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
