We actually know another Steve, of Steve's Auto Barn at blackheath; he owns a BB with white LMGT4s and plates ORSUM. Great looking car, but been ages since Ive seen it.
Here it is!
And here's Chris's. Yeah it's nice. :)
Edited by God_speed
Maclarenf1, As promised. Only had two more pics -
Will have them one day once the engine side is sorted....
Silver LMGT4 looks really nice on a Black R34 GTR with Nismo Skirts and Spats with VS-2 bonnet. (not huge fan of the Nismo bonnet mind you)
This has being my inspiration for few years, which led to me buying my car... Not quite there yet !!!..
^ That looks very similar to God_Speed's car. Fantastic.
Maclarenf1, I'm assuming your car is black. Do you have any pics of it as is?
Pretty standard V-Spec [had a V-spec 2 badge, first thing to come off :) - hate fake badges] - had it for about 1.5 years now, ideally want to do around 1 track day maybe 3 month or so..once the engine is up to that, will think about the exterior...
Runs HKS-Fcon Vpro currently with Stage 1 mods (Only Turbo's to do - getting GT-SS / -9 at the end of the year and she is done)
Also came with some odd bits from japan too like 4 wheel drive controller, modified Diffs, heavy clutch, camber arms, oil cooler, NOT normal FINS on the rear diffuser and a mother of strut bar :)
Currently Runs 239.9 AWKW with 1 Bar + Cam gears on high and stock boost on Low (HKS EBC).
http://imageshack.us/photo/my-images/193/qldraceway.jpg/
http://img844.imageshack.us/img844/313/img1591n.jpg
http://img34.imageshack.us/img34/9316/img1554sd.jpg
Very Envious of you'r car - i am not very good in washing or buffing IMO...
http://imageshack.us...qldraceway.jpg/
http://img844.images...13/img1591n.jpg
http://img34.imagesh...6/img1554sd.jpg
Looks fantastic maclarenf1, thanks for sharing.
Thanks for the kind words. I'm no pro, but if you ever think I may be able to help with some buffing tips - just give me a yell.
M-spec inspired seats sound good, black leather i assume.
Very Nice!
...and some person is privileged to have both VS2 & R-Tune bonnets...
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
