too much blue haha...
lets see some other colours ha... i was going to post some of reds and other rare colours, but struggled abit.
heres another of mine from a fellow forum member taken on the putty road run, i like this shot.
Not enough yellow.
Looking fantastic as always mate, keep the pics coming please.
Got to have a little bit of blue in there -
haha cheers mate, nice pics of the red, blue and white... i like it.
i would like to see some of a yellow one next to some other colours... dont think i have seen any pics side by side?...
heres another of mine from the same photographer above.
Hey mate, this is what I have at the moment.
Nice one mate, think I'm happy I went black instead of white with the yellow..
Phil, Thanks for uploading the pics mate :-)
GTR-34A, cars looking amazing, lovin the Yellow and black theme.... drool.... more,more,more plzzzz.
Cheers mate, don't have many more good pics unfortunately.. Will take more next time I go out
Definately mate, better constrast. You know I think it looks fantastic.
We should get some pics of both of our girls together.
Yea a previous owner actually painted the stock 34r wheels white on mine, but I bought the car without these... I actually have a pic of the car with the white vspecii bonnet onit before it got painted yellow.. Actually looked kind of good ha.
Would love to get some pics of them together mate, next time I'm in sydney with the car I might have to stop in... And if for some reason your going through newcastle with the car, let me know
Black n White themes always work well.
The fact that I opted for black skirts n pods was more dictated by black rear view mirrors.
Yes a black c/f rear wing blade is also tempting.
Congrats on the white R34 above!!!
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
