I like lowered cars but for me, that is a bit too low
Agreed.
Love to look - not to own.
you guys serious?
i dont know why more than 70% of 34 gtr owners are against lowering, and if "twisties" are your excuse pfft
R34 GTR's can run pretty aggressive. I know a person running 19x11 +6 F and +3 R, 275/30/19 all round but no scrubbing.
The car is low too!
Could be possible.
Would have to be rolled at the very least and a bit of camber.
Pics?
I'm running 19x10.5 +12 GT-Vs now for a change and have 15mm spacers on.
So thats an offset of about -3mm. I could theoretically run another half inch on the inside with this offset.
I want some 18x11 +5 or -5 and dial in :)
My cars not really what you call proper though. Slightly wider than real R34s.
what sort of width and offset would I need to run to fill the guards like on that blue 34 GTR ^^ up there, on my 34 GTT?
Sinno might be able to help you and other R34 GTT owners.
Sinno was running crazy offsets for a GTT if i recall correctly.
you guys serious?
I hope I didn't offend u. You have a great car and BB is my favourite colour for the 34 (inline with a white n1 :) aka Terry's car)
Not everyone liked my r34 wheels on my r32 so u can't make everyone happy.
I have this thing with the wrx, evo or gtr cannot sit too low...can I explain it? No hahaha
nah all good fellas
just if you compare 2 gtr's identical side by side, 1 slapped, 1 jacked up . then youll see how phat it looks
something about guard over tread makes the biggest difference to side profile
when i first lowered my car my mechanic couldnt fit the straps under the car and had to raise it 20mm
i asked if thats ever happened before, he said no
I AM BOSS haha :D
Wouldn't say crazy offset, but good enough stance to still make it practical.
I'm running R: 18x10+22 245/40 and F: 18x9+15 235/40.
Note: Its not chrome lol. just very clean!
I'm pretty sure Shinobi_s14 is running tougher offset?
Any scraping issues with this setup or did you just roll/lip the guards?
Yeah SiNNO I've got 18x9.5 +20 on the fronts 225/40 and 18x10 +15 rears, 235/40, just had to roll the guards, thinking about flaring them a tad in the future though but it tucks in real nicely when it's lowered with bit of tyre tuck but had to raise it a tad due to the monster driveway at my place haha
Edited by shinobi_s14
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
