My partner wouldnt do the sexy pose for me.. and someone had to do it.
Cut out my suggestive facial expression to keep this thread work safe.
Damn, I'm in love with your car. There's something just soo right about a clean, aesthetically stock BB gtr
Thanks Chris :)
They aren't bad rims Marko, not exactly the lightest wheels going around but they do look quite nice IMO
I'm thinking about changing to matte black Enkei RPF1's 18x9.5 +15 all around...haven't seen too many 34 GTT's with RPF1's.
Thoughts or recommendations for other wheel upgrades?
how much effort do you think would be required to make an 18x9.5 +15 fit. im looking for new wheels but am wanting good traction as well as offset, so id be looking for something like a 255 on a 9.5 +20 but i fear it would take to much camber/guard work to get them to fit properly. anyone running a 255 on the front of a 34 gtt? otherwise id look at a decent 235 on a 9 +20, but does anyone know of anything comparable to say an xd9 in this offset? cheers
@Spark, nice yellow 34! Is that the 'DIY Lip' I see used all round, even on the skirts?? :P
Was wondering what they'd look like on the skirts if it really is so haha.
On another note, too many GTR's in this thread...
... making me jealous!
thanks for the kind words guys, makes me feel proud of my canary mobile :)
definitely is the El Cheapo DIY Lip kit all round lol turned out okay but im currently in the process of getting together a kit for it
so YAY or NAY for black RPF1's?
ahhbee: would take a bit and money to go into the front guards to make a 18x9.5 +15 fit with 255 tyres...a 235- sized tyre however, makes it a fair bit easier to fit.
I have a good mate with a GTT who is running 18x9.5 +15 all round with 235/40/18 tyres. Rolled guards, camber arms (mainly to go between track/street) and the slight stretched tyre make them fit quite nicely. I'd simply spend more on a nice, sticky 235 than a ok-ish 255 and be happy with that
This will answer your question :)
Matt black would really set it off!
I like these rims because they are very well priced and different to what you would expect to see on a skyline. If I had an r34, I'd run these wheels.
I was even thinking of buying a set for my 32 but they don't suit the car as much with the high detail and intricate design.
index-15.php
Edited by Marko R1
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
