My partner wouldnt do the sexy pose for me.. and someone had to do it.
Cut out my suggestive facial expression to keep this thread work safe.
Damn, I'm in love with your car. There's something just soo right about a clean, aesthetically stock BB gtr
Thanks Chris :)
They aren't bad rims Marko, not exactly the lightest wheels going around but they do look quite nice IMO
I'm thinking about changing to matte black Enkei RPF1's 18x9.5 +15 all around...haven't seen too many 34 GTT's with RPF1's.
Thoughts or recommendations for other wheel upgrades?
how much effort do you think would be required to make an 18x9.5 +15 fit. im looking for new wheels but am wanting good traction as well as offset, so id be looking for something like a 255 on a 9.5 +20 but i fear it would take to much camber/guard work to get them to fit properly. anyone running a 255 on the front of a 34 gtt? otherwise id look at a decent 235 on a 9 +20, but does anyone know of anything comparable to say an xd9 in this offset? cheers
@Spark, nice yellow 34! Is that the 'DIY Lip' I see used all round, even on the skirts?? :P
Was wondering what they'd look like on the skirts if it really is so haha.
On another note, too many GTR's in this thread...
... making me jealous!
thanks for the kind words guys, makes me feel proud of my canary mobile :)
definitely is the El Cheapo DIY Lip kit all round lol turned out okay but im currently in the process of getting together a kit for it
so YAY or NAY for black RPF1's?
ahhbee: would take a bit and money to go into the front guards to make a 18x9.5 +15 fit with 255 tyres...a 235- sized tyre however, makes it a fair bit easier to fit.
I have a good mate with a GTT who is running 18x9.5 +15 all round with 235/40/18 tyres. Rolled guards, camber arms (mainly to go between track/street) and the slight stretched tyre make them fit quite nicely. I'd simply spend more on a nice, sticky 235 than a ok-ish 255 and be happy with that
This will answer your question :)
Matt black would really set it off!
I like these rims because they are very well priced and different to what you would expect to see on a skyline. If I had an r34, I'd run these wheels.
I was even thinking of buying a set for my 32 but they don't suit the car as much with the high detail and intricate design.
index-15.php
Edited by Marko R1
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
