^ Thanks for the thread revival, had been a few days since the last pics.
Yours were definately worth the wait, thanks for sharing.
I may be wrong, but is that red skyline an R33 with a R34 front end? Just looking at the door lines and handle, looks like R33.
red one - 1993 r33, was modified with engine swap for rb25det, all body had modified - gtr33 : rear fenders, sideskirts (metal ones), and gtr34 - front bar with hood. the front fenders 334 are custom made. paint - House of Color Apple Red Candy
you can check the project with some pics here, although it's in russian...
http://www.nismo-club.ru/forum/index.php?showtopic=38796
blue one er34 GTT MT, body - all round gtr 34 (including original rear fenders, all front with Z Tune bumper). paint House of Kolor Cobalt Blue Candy
will update with more pics soon..
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
