19x10.5 +12 perfect fit no issues (besides not being able to fit bigger brakes)
What's the problem? Diameter clearance or spoke? Or disk type?
If those sizes don't fit. I won't be able to run Meisters.
I THINK its just the clearance on the GTR calipers but it can be overcome by a small 3mm spacer or something..That's what someone told me when getting my wheels...
NO problem doesn't need any spacers fit standard brakes perfect ! I meant later down the track can't run bigger callipers with those rims
Is it a diameter of rim or caliper to spoke clearance that will be the issue? Ie. will a 365 rotor 8piston Brembo fit.
I've got 6 piston Alcons with 365mm rotors on 19x10.5 +22 and have plenty of spoke clearance. When I had them fitted, I was told even 8 piston were fine.
I run Endless 6 piston at the front and Endless 4 piston at the rear.
The Volk TE37 in 19 x 10.5 +12 where the only rims that fit over the callipers with no spacers required.
Both the SSR SP1 and Work Meister in a 19 x 10.5 required 10mm spacers to clear the front callipers.
This all relates to offset though, I am unsure about the overall diameter, but do know that the Enkei NT03 in 18 x 10.5 did actually fit, both offset and diameter wise.
Here are some shots of these rims on the car...
Do you know what "disk" they were?
19x10.5 in Meisters come in multiple disks.
http://www.workwheelsusa.com/media/wheels/29/85/Meister%20S1%203P%20Spec.pdf
I know for a fact that 17x9.5 +12 lmgt4 and te37 fit all over a 8 piston brembo with 365 rotors. With plenty of room to spare.
Good question, no sorry, I am not sure.
This shot shows the clearance with the TE37's.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
