new plates... I boost
Dont worry eyelids getting back on soon, along with spoiler coming off again
Good idea...
If only we could use 7 letters, I can think of plenty with 7.
Anyway, I also bought two custom plates back in May:
The 'WJ' were originally going onto the R34... but I liked the look of the Targa plates better :D
BTW - last time I checked, 'R34' was still available in Tassie.
I *nearly* ordered them but the Targa plates were half the price - and if I sell the R34, the plates would only suit another R34, so...
clean engine
well, had to take a wheel off today to check if it was leaking or if i drove over a nail cause my pump didn't work.
Didn't sound safe with the jack below it and i didn't want to take it any higher and place a stand below it so grabbed out a 18" SSR rim with 285 x 30 x 18 on it :D
There is a spacer in there.
I dont like the white on chrome.
Thoughts?
Edited by Owgasm
clean engine
Didn't sound safe with the jack below it and i didn't want to take it any higher and place a stand below it so grabbed out a 18" SSR rim with 285 x 30 x 18 on it :whistling:
Thoughts?
your R34 looks...wierd? should paint the bottom lip or something and clear front indicators. cause looks like the front is higher then the rest of the car.
id stick with the old rims, black chrome lip, and maybe some c/f ganador mirrors
Yeah, its a 33 :thumbsup:
But possibly cause its on a hill, so the rear is experiencing my force downards.
The front looks odd cause theres no lower lip, i reckon any GT-R 34 requires the lower lip/diffuser, else it looks funny.
I've been looking for years, believe me i've noticed.
But i wouldn't paint it anyways :P
I prefer the black and chrome lip. These others wouldn't fit anyways, the rears are 335's.
Edited by Owgasm
and bakes, I LOVE your garage, so clean and simple :thumbsup: very jealous
Thanks buddy. I painted it just before I picked up the GTR. My missus laughed at me when I said I was going to paint the garage red (was a dirty white color before) but it came up sweet!
Hi Bryn, it's just the flash.
Would be good if the doors had lights instead of reflectors though.
yeah i remember when i got the car in 05, i took them off thinking the bulbs had blown but couldnt find anything :(
when i saw urs i was like :O no way lol
when i saw urs i was like :D no way lol
Hehe :D
Yeah, I had much the same idea when I first got my 34 - I thought the bulbs had blown.
Ok, thought i'd post a couple of my pics of my GTT R34 ,, yes it is a GTS-R badge.
Top Secret GTR front bar and Z-Tune Bonnet
Sorry pics not best it was raining at the time.
thanks for looking, just needs the top secret front diffuser lip
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
