Well ive done quite a bit searching (no doubt like adz2332 did) and I think ive found the right vehicle.
1996 R33 Series 2 RB25DET manual,turbo. silver.
looking forward to completing the inspection and payment by end or mid this week sometime so I can go for a few cruises with u guys over the coming months.
I wanted to buy stock, and then mod it all myself and I think ive found just the right car to start thinking about some serious mod projects. it looks nice and clean apart a key scratch which im getting fixed asap and its dyno @ boostworx shows 156kw at the wheels now on stock boost, 5zigen exhaust system and a pod air filter from K&N.
so pending the events coming up during this important week, its looking bright for the future.
https://www.sau.com.au/forums/topic/146760-buying-my-first-skyline/
forum rule (so ive found out)
pics or ban
:P
sure... heres the link to the car...
http://www.skylinesaustralia.com/forums/in...9&hl=Zertek
im setting up RAA check today and finalising payment within next 2 days for him then hopefully by end of this week ill have it in the garage.
ill post a few pics up in a sec from that link there for people who are too lazy to click.
looks good mate almost identical to mine! What did you end up paying for it?
well havent payed zertek yet, but we agreed on an amount under 15 grande.
as i said, pending RAA inspection which I think should pass the test. car drove smoothly on the test drive no steering wheel rattle, corrected nicely etc. now compression test and stethoscope test for the bottom end then by end of this week hopefully i got it. no reason apart from RAA telling me motor is on its way out that i shouldnt have this car in my possesion in a few days.
Edited by SAZilla
Beware that the RAA are often very hard on cars inspection wise, which I think is good - I had a car inspected and they even commented on "wear in drivers carpet" - lol the car was like 4 years old, were they expecting new!
Look at the list that they provide, and make your own mind up as to whether you think the things they find are acceptable or not.
Most of all, best of luck with the new purchase mate.
They can go the other way as well. My mate was selling a car and had a check done from a potential buyer. The RAA listed a noisy diff, which the car never had any problems, or diff issues. It was the guys personal opinion of how the car was.
Also, they cannot pick up everything that could be wrong with the car. I had a check done on my car when i first bought it, but it didnt stop the engine from letting go within 3000kms due to a dodgy 100k service at local turbo tune-rs. :P
So should I still go with the RAA? im a member so i thought id get it a bit cheaper and if they are RAA approved they got to be up to some standards.
I wasn't suggesting you didn't use them, but rather you don't take everything they say as gospel, but make up your own mind about what they've written.
oh k. i just paid for the full inspection 202 dollars. this definitely is the car i want to buy but of course for peace of mind, i just have to do it. 2moro ill get the results stick em in here and u can tell me what yall think.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
