New n1 turbos for gtr and power fc with hand controler
location is on the gold coast
reason for selling im upgrading to a massive single turbo and a link computer
price $2000 for the n1s and $900 for the power fc or you can have both for $2700 i am open to offers
turbos come with brand new 3inch stainless dump pipes and come with all the lines and both manifolds
will have some pics up in a couple of dayz
contact me on 0410189246 ...... ask for luke
..........................................................ALSO OTHER PARTS AVAILABLE.......................................................................
.......................................price drop..............................................
Edited by turbobmw
https://www.sau.com.au/forums/topic/146834-new-n1-turbos-and-power-fc/
whats the serial number on the turbo's?
hey bro pulling the turbos off tomorrow can tell you then ........if you build it , they will come ......amen to that
Edited by turbobmw
yeas... R34 N1s are Ball bearing.
and bigger
EDIT:
BNR32 (NISMO)......Serial No. 14411-06U00 (F/M273 deg. plain thrust bearing centre)
T04B Compressor with a 0.42 A/R and 62T
T25 Turbine with a 0.64 A/R and CD79
BCNR33 (N1)......Serial No. 14411-24U10 (F/M360 deg. plain thrust bearing centre)
T3 Compressor with a 0.42 A/R and 55T
T25 Turbine with a 0.64 A/R and 62T
Included this for information...all R34 GTR's are Ball bearing turbo's...all previous models are only plain bearing.
BNR34 ......Serial No. 14411-AA300 (Ball bearing centre)
C100 Compressor with a 0.53 A/R and 50T
T25 Turbine with a 0.48 A/R and 62T
BNR34 (N1)......Serial No. 14411-AA401 (Ball bearing centre)
BNR34 (N1)......Serial No. 14411-AA402 (Ball bearing centre)
BNR34 (N1)......Serial No. 14411-AA403 (Ball bearing centre)
C106 Compressor with a 0.60 A/R and 55T
GT25 Turbine with a 0.64 A/R and 62T
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
