***no Limits All Street Car Events - 2007 Event Dates***
As the old saying goes: Don't let fear hold you back.
The caveat being: Don't confuse bravery with stupidity.
Anyway, it would be good to see some more times posted up for Wanneroo. Everyone else must think we are a bunch of keyboard warrior weiners for not posting anything.
  • Replies 46
DJ I dont see your name on the entry list, I hope you are coming. Although I did hear a wisper that you may have sold your broom broom.
CR
I would refer you to the previous statement about keyboard warrior weiners. That's me. Can't make it Thursday (work), but will be there Saturday for the SES.
here's some basic pics. never really done this before so wasnt sure what i was doing with lighting and well everything. go easy on me
http://www.dantheman.com.au/Wanneroo/1.JPG
http://www.dantheman.com.au/Wanneroo/2.JPG
http://www.dantheman.com.au/Wanneroo/3.JPG
http://www.dantheman.com.au/Wanneroo/4.JPG
http://www.dantheman.com.au/Wanneroo/5.JPG
http://www.dantheman.com.au/Wanneroo/6.JPG
http://www.dantheman.com.au/Wanneroo/7.JPG
http://www.dantheman.com.au/Wanneroo/8.JPG
http://www.dantheman.com.au/Wanneroo/9.JPG
http://www.dantheman.com.au/Wanneroo/10.JPG
http://www.dantheman.com.au/Wanneroo/11.JPG
http://www.dantheman.com.au/Wanneroo/12.JPG
http://www.dantheman.com.au/Wanneroo/13.JPG
http://www.dantheman.com.au/Wanneroo/14.JPG
http://www.dantheman.com.au/Wanneroo/15.JPG
http://www.dantheman.com.au/Wanneroo/16.JPG
http://www.dantheman.com.au/Wanneroo/17.JPG
http://www.dantheman.com.au/Wanneroo/18.JPG
http://www.dantheman.com.au/Wanneroo/19.JPG
http://www.dantheman.com.au/Wanneroo/20.JPG
http://www.dantheman.com.au/Wanneroo/21.JPG
http://www.dantheman.com.au/Wanneroo/22.JPG
http://www.dantheman.com.au/Wanneroo/23.JPG
http://www.dantheman.com.au/Wanneroo/24.JPG
http://www.dantheman.com.au/Wanneroo/25.JPG
http://www.dantheman.com.au/Wanneroo/26.JPG
http://www.dantheman.com.au/Wanneroo/27.JPG
http://www.dantheman.com.au/Wanneroo/28.JPG
http://www.dantheman.com.au/Wanneroo/29.JPG
http://www.dantheman.com.au/Wanneroo/30.JPG
http://www.dantheman.com.au/Wanneroo/31.JPG
http://www.dantheman.com.au/Wanneroo/32.JPG
http://www.dantheman.com.au/Wanneroo/33.JPG
http://www.dantheman.com.au/Wanneroo/34.JPG
http://www.dantheman.com.au/Wanneroo/35.JPG
http://www.dantheman.com.au/Wanneroo/36.JPG
http://www.dantheman.com.au/Wanneroo/37.JPG
http://www.dantheman.com.au/Wanneroo/38.JPG
http://www.dantheman.com.au/Wanneroo/39.JPG
http://www.dantheman.com.au/Wanneroo/40.JPG
http://www.dantheman.com.au/Wanneroo/41.JPG
http://www.dantheman.com.au/Wanneroo/42.JPG
So Paully,
How was the Down force with that wing lolololol, good to see the gay wing out and about, you have been hiding that in the closest for too long and glad you come out with it :no:
Looks like it was fun, have to come out next to time.....
Great...more Skylines to give me grief, mind you I did get to pass two of you's :O
It was good to see such support from the skyline crowd and nearly half of the drivers were 1st timers which is great to see more people getting involved. Once the time grouping gets sorted it'll be even better :)
i went and had a look for a hour or so and looked like great fun, ill more than likely get the stagea out onto the track and see how the heavy thing goes lol. Paul your car sounds great and bobbos gtr is f**kin crazyy :O
what sort of tyres and brake calipers/pads were u using Paul? and did u have any issues with brake fade?
i just hope my brakes are up to the task with the 1650kg boat i got, might need to upgrade the pads to something more track friendly :)
Brad, I'm running Hawk race pads, RDA sloted rotors, and braided brake lines, and I was noticing some fade, but was able to last 3 hot laps ok.
yer sounds like i might be ok then, what calipers do u have? gtst or brembos?
i got brembos, dba 5000 rotors, stock brembo pads and braided brake lines so maybe just a pad change as i cant see the stock pads being much good for track, though i havent tried them much yet to see.
Edited by CruiseLiner
haha how is the bonnet scoop doing feeding air to that top mount? hahahaha
This event was awesome. Having an instructor drive your car can only be described as an 'experience'. I would pay the $150 for just those laps.
Good pics Dan, not bad for a first attempt.
Edited by Brockaz
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
