------------------------SOLD-------------------------
- 1990 type-m model
- Personal import in 2004
- rego till july 07
- 5 speed manual
- Shows 58 XXX klms
Money spent:-
- Fresh professional respray in original midnight blue but with extra pearl ( 1 month old)
- Shaved bootlid (lock)
- Gtr Bonnet, Gtr grill and Gtr front bar
- Front Mount intercooler and Alluminium piping
- Kakimoto 3.5" exhaust with Kakimoto Cannon and highflow cat
- 18' drift style rims with silverstone rubber with 70% tred left
_ 3 Point immobiliser alarm (insurance approved)
- Lowered on King springs
- Boost gauge, turbo timer etc etc etc the list goes on and on
Always serviced at 5k intervals using motul turbolight oil, just had replacement of brakepads and gearbox oils and diff, platinum plugs. Never had problem except for a disconected wire in the AFM. Runs beautifully and will satisfy fussiest buyer. Car has NEVER ever seen a boost controller of any kind.
To contact me call 0411170084
Located in Coffs Harbour hallfway between brisbane and Sydney
Edited by carbyfed
forgot to add all badging has been removed too plus it has a pretty good stereo. Only selling due to wanting a ducati and I now have a company car and regretfully hardly drive this machine. Will get some photos of the rear today or anyother anybody wants.
PM me what you are willing to take for it with stock wheels...
id rather not say how much i would like to offer you on the forum, you have a pm on the price im willing to offer im in newcastle but frequently travel to port to see family so i could come up and have a look serious on the offer no stuffing around.
aaron
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
