now ive had a turbo gtr/gtr for the last 4 years
never had a problem before
but in the last two weeks it has been busted into twice. i live in a very quiet part of padsow that noone ever comes down so they obviously have been checking the car out for a while.
now last night i cought them in the act (over at a mates place)
they couldnt get it started and left
so i called the cops
then the brains came back with 4 mates in a civic.. they scoped the car out for a bit did a few drivebys. i called the cops again
they were heading to the car so ive come out (not very smart) and they did the bolt. no point chassing i had about 12 beers
cops turn up 1 minute later and go hunting
cops say what car was it
i say skyline and they finsih the sentance "GTR"
anyway i now need a new key barrel and lock and new turbo timer
if only i had a gun
this is the only time the car has been outside in its life and it was in a pivate parking spot at a mates place in abbortsford
pete
https://www.sau.com.au/forums/topic/14729-theft/
  • Replies 54
Well,
It seems like ure in a loose/loose position atm. Expect them to come back, so it might be time to revise ure alarm setup and drop something new in there, like a tracka perhaps?
Might also be a good idea to drop ure baby into storage for a month or 2. Sure its a pain, but if they get to ure car and can't tax it, they might be inclined to key it etc.
https://www.sau.com.au/forums/topic/14729-theft/#findComment-298569
yea its got a few kill switches
now has a 4 point immobilizer
never gets parked on the street
my gtr key only works on the door now and i have a gay gts key for the ignition
i think thiefs r lower than parking inspector they all should dye
car is for sale im sick of the hassels
pete
https://www.sau.com.au/forums/topic/14729-theft/#findComment-299014
Dan I was thinking the same thing..........
He he - yeah Pete - I'll swap you for mine - Cheaper insurance, Not as old, maybe less milage, less hassle, more sideways action and give a GTR a good run for it's money.......:):P
https://www.sau.com.au/forums/topic/14729-theft/#findComment-299981
I cringe when I hear of this stuff now. It just sucks to know that you can't leave your valuables anywhere... This is the worst thing about owning such a schmick car. Perhaps you should consider mounting a bull bar to the gtr and go hunting for the little bastards... :headshot:
https://www.sau.com.au/forums/topic/14729-theft/#findComment-301243
Guest Da_Man
Fatz, sounds like you need to do what i have done. Go to rebel sport and buy yourself an alloy baseball bat and keep it in your house.
Let this be a warning to anyone i find that should not be there. I have had enough from the crap job that the police do.
Like the sign says “Person found here at night, will be found here in the morning” (with a little picture of a gun)
https://www.sau.com.au/forums/topic/14729-theft/#findComment-302892
Haha. I like that one! want to get something like that for mine...
I'd love to come up with some ingenius anti-theft device. One of the guys from work used to have a motion activated webcam setup out the front with sensor lights. That worked well, but you really need something that's going to deter them immediately.
https://www.sau.com.au/forums/topic/14729-theft/#findComment-303318
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
