  • Replies 54
Guest SiM97
one warning for you guys dont park in city at night or even during day! live in the city for past six months and i just have to look out the window and see some little prick having a go at a car! Isnt always but at least once or twice a week and i dont mean 2 am this is at 7pm!! usually liitle kids with track suites and basball caps and a flash light. im going to catch me self one of those kids one day!! and he wont be home 4 dinner ! i promise guys! i really hate the little pricks, they always work in groups
https://www.sau.com.au/forums/topic/14729-theft/page/2/#findComment-306045
I think if i ever had a chance of catching up with someone who was trying to break into my car or steal it i'd probably end up in jail charged with something.
If my steering lock isn't on the steering wheel its on the passenger side floor only an arms reach away.
They'd certainly wake up with a red "Pro-Lock' mark indented on their forehead thats for sure.
https://www.sau.com.au/forums/topic/14729-theft/page/2/#findComment-306416
Originally posted by Silver-Arrowz
If you catch the pr*ck, call us cause I have thought of a few experimental torture techniques we could try.
:werd:
[quote PULP FICTION
"Bring out the Gimp..."
[/quote
https://www.sau.com.au/forums/topic/14729-theft/page/2/#findComment-306619
Originally posted by fatz
my gtr key only works on the door now and i have a gay gts key for the ignition
i think thiefs r lower than parking inspector they all should dye
car is for sale im sick of the hassels
pete [/b]
why dont you get ur ignition lock recoded to fit ur GTR keys?
i recoded all my locks to a new key when i bought my car....cost about 45 for igntion, 20 for each of the others (2door, boot)
sum ppl might think its ova doing it butmy mate got his car stolen the next night after he bought his....
https://www.sau.com.au/forums/topic/14729-theft/page/2/#findComment-318342
I know a Harley guy who is in Jail because he rigged a switch that diverted the distributor spark from the spark plug to the petrol tank. The thief hot wired his Harley, did hot turn the switch hit the start button and then hit terminal velocity in every direction. A little extreme and the court thought so as well.
https://www.sau.com.au/forums/topic/14729-theft/page/2/#findComment-327711
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
