hy, this might be weird, but ive been looking for a dash tray insert to place were the original stereo leaves a gap after putting in a cd deck.. any one know were to get one like this, looks like its a perfect fit in the dash gap..
nissan should be able to supply this
theyre bout $50 bux from memory but if you kick down to super cheap and get the universal clip in aeropro one, with a little DIY and thought (you dont actually use the clip in feature, you screw it to the metal bracket where you bolt you cd player to) you never know the difference and it will only cost you $15 did it on a mates bout a week ago
Edited by wessa02
hey nice,.. i was sorta thinking about customizing one.. the one i have nowe from super cheap loox to cheap :devil:. and pops out a bit. i might try what you said .. thanx
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
