hey all was just wondering if there is some sort of trick to adjusting coilover height.
ive undone the locking nut and now using the c spanner to try and tighten it so that my car is higher of the ground, this seems to be almost impossible. it moved a little but no were near enough as i need to move it, any secrets that i don't know about.
ta ben
https://www.sau.com.au/forums/topic/147768-adjusting-coilover-height-help/
assuming its the same as my Teins, to raise it you are screwing it upwards, compressing the springs..and hence it gets harder the more you want to raise it...spraying WD40 + a fair bit of elbow grease would get you there...
When I have to do this with my coilovers, I take the struts out and use spring compressors. We have some real big ones at work so this makes it alot easier. It sounds like more effort, but it's actually quicker and easier. If you have access to some spring compressors, I would suggest you do that
with coilovers, when adjusting those 'nuts' you arent compressing the springs, all ur doing is sliding the whole unit up/down itself, through the thread. so to raise the height of the car, wind the screw towards the ground, also the distnace u move the nuts is proportional to the change in height of the car from the ground
Umm.. spring seat going down means the car is getting lower. Sping seat going up raises the car. The height change is not proportional once the spring is trapped and you are compressing it.
If you wind the spring seats up far enough, you do start compressing the spring and giving it preload.
Not when u use the c-spanners it does not compress the springs. It's kinda awkward to explain without pics...
If you wind the spring seats up, the spring gets compressed. If you have helper springs, the helper crushes and the main spring doesnt.
I can't really see how it doesn't. Care to have some fun in MS paint? :teehee:
Or are you talking about base height adjusment?
OK here goes. pic is of my Teins (rears) currently at the lowest height setting...I have now wound it UP to raise the car and by doing so, have compressed my springs..
ahh yes now i see. well with those teins, yes the springs are going to compress/extend when u adjust them.
however with the set of teins i put in a mates car recently, the adjustment grooves were closer to the bottom of the cylinder, and had nothing to do with the springs. this is by far the better design IMO
You are talking about base height adjustment. Those should also have preload adjustment. I have never seen any coilovers that have had only base height adjustment, always preload aswell
Pardon my ignorance but what is preload and how do you adjust it in my case?
Spring force are proportional to displacement. Preload is giving an initial displacement of less than it's free height, so it's giving a force on the spring before the weight of the car is on it.
Preload adjustment is the spring seat adjustment. The effect of preload is nothing as far as I'm concerned in a car as you need an incredible amount of preload before it still has some preload when the weight of the car is on it. I.e. If there is sufficient preload, it will take the whole weight of the car and more before the actual loads negate the preload and cause the spring to be linear
Sorry for the crappy explaination, bit tired right now...
Edited by salad
Just imagine your spring without any tension on it all as in dropped to it's fullest extension i.e. no preload . Now as you wind up the adjustment nut it compresses the spring and thereby creating preload and effecting a certain amount of height reduction due to the spring having less travel/compression. Tein Type Flex have damper height adjustment (fulled threaded shell) which allows for the height adjustment to be done without affecting spring preload. Type Flex also allow you to change the spring perch height thereby changing preload and have rebound (valve) adjustment as well. EDFC work great on these.
Check the Tein website for pics.
Changing the preload on yours is simply done by winding the spring up or down. The Type Flex type of damper are by far the better unit IMVHO. Other manufacturers have similar units although Tein are great quality products.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
