  • Replies 77
Cool idea Skip .... it would rock the socks off the rest of the audience watching a large number of Skylines/Jap Imports rock in to the movie :(
Then we could do burnouts etc down the front at the end of the movie .... or not
https://www.sau.com.au/forums/topic/14777-cruise-idea/#findComment-304267
u guys better get advanced tickets .. can u even do that for drive in?? cause i reckon that place is going to packed out with hoons, revheads and nightcrawlers !!!! if the cops were smart they'd set up an inspection site and check out all these modified cars ... oooopps .. they're reading this aren't they??
https://www.sau.com.au/forums/topic/14777-cruise-idea/#findComment-317852
That's a thought... I'm gunna be there real early, park at the gate and set up a BBQ...
Let's me see... setup + cook + eat... about 1.5 hours... be at the gate by 5pm... gate opens 7pm... then:burnout:
Graham
https://www.sau.com.au/forums/topic/14777-cruise-idea/#findComment-317930
Nozila .
Paul Walker is going to be at Melb, Syd, Bris, and may be coming to Adelaide it s only what I got told from the promotorrrrrrrs who are doing it.
going to ths drive in sounds great and would be a site to see but Im just passing out other information . Timmmayyy I get most of my information from SVD because we have some sponsors and people who work in these areas who are apart of the CLUB who let us know of what is going on.
Enough of that a quick question ???? has the driver of the Sub Zero fixed his R32 turbo oil leak yet???? Boy it was smoking a few weeks ago.
Oh yah hey Munro got the new car yet????? you know which one I mean??????
https://www.sau.com.au/forums/topic/14777-cruise-idea/#findComment-318477
Originally posted by her200sx
back to the cruise idea..sounds wicked..gotta pick a place to see it...probably Friday the 6th of June would be a good idea...as fridays seem to be cruise nights...  what do ya reckon.?
I'll be going to see it on Friday night and most likely at the around the 7pm, as I have 4wd drive trip with a group for the long weekend to the Border Track... I can't go any other nights. :burnout:
Cheers,
Graham :D
https://www.sau.com.au/forums/topic/14777-cruise-idea/#findComment-340805
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
