  • Replies 83
LPG needs a high compression ratio to realise its full potential. Dual fuel vehicles don't really show off gas because you have to tune it for the lowest denominator. LPG is a much cleaner alternative to petrol and currently it's cheaper, but it seems the govt has already started to dig its claws in there too :\ Bastards. But yeah, rebuild an engine to run on pure LPG and it'll be cleaner and will potentially make more power too. I heard someone had made LPG injectors too, dunno whether it's true or not but effectively having to go back to a carby system (mixers) was always one of the shortfalls of an LPG system.
gas is still made from crude oil. burns in a similar way and gives off most of the same chemicals. your prob thinking of hydrogen gas not lpg. when the oil goes, so does lpg.
Yeah, but we have excess LPG and it is cleaner
IanB: Haha, ride a pushie to uni... I'll leave 9pm and get to uni in time for classes at 9am!
Hydrogen isn't viable yet.
I don't know anything about the performance side of LPG. Don't know much about fuel either in regards to performance :(
Mush: 50L.
The car does have horrible fuel consumption though - living in a hilly area doesn't help. I just can't afford a replacement :)
Ska: LOL. Maleny is two townships away. About 15 minute drive.
Edited by Midol
So you are in Montville, oh dear god, an upper-class HIPPIE!
I have no idea whay my posts have to do about this thread but all hippies should be shot, oh yeah and we all should read up on peak oil, it is very interesting subject:
http://www.google.com.au/search?q=peak+oil...rch&start=0
There is no train station at USC. (Ok, so it'd take 3hrs to ride, not 6.)
When I go to QUT though I will be taking the train. Might even ride there some days! It's only a 30 minute ride to the station so it aint that far, but the roads arn't made for bikes so I'd probably get hit, lol.
Guess what everyone. The petrol was cheaper yesterday than it was today! Because thats what happens.
Low and f*&king behold the earth didnt stop spinning!
And I still got 10kms/L with my headlights on, wipers on, a/c on, and stereo right up driving in the rain.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
