the 2007 drift calendar is quickly filling up. Here are dates for several competitions that i am aware of...
Drift Australia
Round 1 - Barbagallo Raceway, WA - Feb 24 & 25
Round 2 - Mallala Motorsport Park, SA - April 14 & 15
Round 3 - Eastern Creek Raceway, NSW - July 7 & 8
Round 4 - Queensland Raceway, QLD - August 11 & 12
Round 5 - Oran Park Raceway, NSW - September 22 & 23
Queensland Raceway
Drift Day - January 21
Queensland DriftState Championship
Round 1 - March 4
Round 2 - May 13
Round 3 - September 2
Round 4 - November 18
Saturday Night Drift Comp
March 17
May 5
July 14
August 18
September 22
December 1
Friday night Drift Practise
February 2
March 16
May 4
June 1
July 13
Aug 17
September 21
November 2 & 30
Stadium Drift Masters
new comp for 2007. Held at under lights at Parklands on the Gold Coast, it is run by Raceline Promotions, the same people that bring you Super Sunday, Street Torque and Hyperzone to name a few.
Round 1 - Jan 27
Round 2 - March 24
Round 3 - April 21 (Hyperzone)
Powercruise
i am assuming drifting will continue to be a part of the Powercruise lineup...
September 6/7/8/9
June 23 is the Powercruise Powerplay
there are a few other comps i'm hearing whispers of. i will update this thread with details if they go ahead.
https://www.sau.com.au/forums/topic/148206-2007-drift-calendar/
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
