As the toppic states i have come into a bit of trouble with my r33 gtst series1. Yesterday after a short drive i realised a loud tapping noise coming from the engine i poped the bonnet and it was even louder. It seems to get louder when you apply more throttle but im no mechanic i got a long handled screwdriver out and listened through the end of it and could hear the tapping coming from this part . The pic attached is one i found doing a search. In Red is the part the noise is coming from and the the Yellow indicates the belt attached to it. Whatever it is it is causing the belt to split from the edges so the question is. What part is it? Is it still safe to drive? and how much to fix it your help would be greatly appreciated thanks guys, cheers.
Matt
https://www.sau.com.au/forums/topic/148219-loud-tapping-noise-please-help/
Matt
Hi,
It's your air conditioning compressor.. Best to take it to a radiator shop or an a/c shop..
Thanks,
Scott Roberts.
If the noise is there when the air cond is not on it could be the idler bearing ( seized , dry etc...) , thats the pulley whre the red line meets the yellow (bottom part) . With air cond off check to see it the air cond compressor turns ( it shouldn't ), just the pulley should spin . If it turns the clutch could be stuffed, Anyway if you dont care about air cond , just take the belt off, when you fix the problem then you put the belt back on .
is anyone else worried that the ac compressor is bolted to the block, and the noise could be a spun bearing?
i could be wrong (i hope i am), but get that belt off ASAP so you dont do any more damage if it is a bottom end problem.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
