Hi all,
I've got this nasty vibration between 1500 and 2000RPM and I'm wondering if a stuffed gearbox can caus this?? Is there anything in there that will caus this vibration/noise?
It sounds like a million heatshields are loose....
The box is old.. my syncros are starting to go as well...
Any help would be great...
Thanks,
https://www.sau.com.au/forums/topic/148236-vibration/
Got that same noise.. only when the car is under big load im guessing?
and completely goes away over 2000-2500rpm?
Im guessing either tailshaft.. or rear diff.. Having mine looked at early jan.. will report back with what i find
p.s. my 2nd and 4th gear syncros are going too :laugh:
https://www.sau.com.au/forums/topic/148236-vibration/#findComment-2776577
  • 8 months later...
i have a similar problem, can hear some sort of noise/vibration but goes away at 2.5k rpm
mechanic says its the clutch that is out of balance or gone
I have just rebuilt my gearbox and the guys I have been speaking to say that it can be 'hot spots' on the flywheel. Get your flywheel machined and see what happens. Only problem is that if the hot spots are fairly bad, then the hot spots will come back because the hot spots change the form of the material of the flywheel.
After saying that, I have had mates with Exedy clutches like mine was and they have been known to give bad clutch shudder.
I have since brought the 'full monty' clutch kit from Jim Berry in QLD. Had it shipped to me here in Melbourne. 3100lb plate pressure. Gret clutch. Jim assures me that I will not get clutch shudder so I will see how I go.
It can be quite common to get clutch shudder with performance clutches though guys, sometimes we just have to put up with things like this if we want the hi performance bits and pieces...
Anyboody else having these issues??
https://www.sau.com.au/forums/topic/148236-vibration/#findComment-3366075
  • 2 months later...
Just had my gearbox oil changed and my box is still vibrating on load and sometimes on idle. Also appears the main bearing is on its way out. Just wondering what the vibration may be. Have a brass button clutch in it. 4th to 5th is crunchy as well.
https://www.sau.com.au/forums/topic/148236-vibration/#findComment-3517121
Tek, me and you always seem to end up with the same problems on our skylines lol. I'm having this exact same problem. Clutch was just replaced with a Jim Berry made clutch, hd organic type with 2100 clamp load. Noises occur whilst accelerating before about 2,500 to 3000rpm in all gears, except for maybe 5th?? Not sure about 5th.
My fly-wheel was machined when they replaced the clutch. Throw-out bearing was replaced. This was only a week ago. I replaced my gearbox oil about 2 months ago with Motul 300. Wtf is this noise lol. It's not cool hey.... fix one thing, another breaks.. Still love my skyline, but man.....
EDIT - Gearbox feels completely fine to drive, no gear changing problems etc that would suggest synchros??? Please help.
Edited by Simmo1985
https://www.sau.com.au/forums/topic/148236-vibration/#findComment-3533481
  • 2 months later...
anyone has any solution to this??? im also facing sucha prob... only at low revs, esp when da engine is under heavy load. once rev past 2.5k rev, den all goes smooth n the sounds disappears...!!!
mechanics told me its due to clutch bearing, but i highly doubt that, as if clutch bearing is not in good condition, when da car is idle, by engaging n disengaging the clutch, u'll hear noise differences... thats da tell tale of a worn out clutch bearing.
but this problem only arises during revs btw 1k to 2.5k... sometimes it gets realli noisy...!!! could it be the tail shaft? any more ideas???
anyone solved this problem???
https://www.sau.com.au/forums/topic/148236-vibration/#findComment-3681510
sorry, what do you mean by "last mechanic changed the clutch he put the tailshaft on 180 degrees out"???
the tail shaft u referrin to its da long shaft, dat joints to the coupling? is that what u mean? so basically is the coupling joint issue??? or da tail shaft dat connects to da rear axle? or to the main gear box?
sorry im really unclear of all this terms.....
https://www.sau.com.au/forums/topic/148236-vibration/#findComment-3684333
What he's saying is, when the tailshaft is removed, mechanic will mark the position where it sits so that when it's replaced he puts it back in the same spot. Refitting the shaft in incorrectly results in an unbalance thus causing a vibration.
I have this problem too. Has anyone taken their cars on the freeway and popping it out of gear? I have, so that cancels out clutch problems. Also had new tyres fitted and a full balance carried out. Pineapples have also been fitted. Running out of options. I'm sure someone has had this problem and fixed it by now.
I call these people... Leechers! Lol!
https://www.sau.com.au/forums/topic/148236-vibration/#findComment-3695039
  • 1 month later...
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
