  • Replies 67
mines are:
1. get a girlfriend
2. lose weight
3. buy a property before i spend too much money on my car
4. pass everything at uni
i will tell yous how many of these actually come true at the end of the year
mine is
1. keep my gf
2. put on weight - i need to put on 15kgs to be at my ideal weight/height :)
3. pass everything at tafe
  1. Pay off all my loans and sell one of my cars. too much for a 20yr old :nyaanyaa:
  2. organise to go to uni mid this year or next to study accounting
  3. meet more people that i havent met before
  4. finally build one of my dream cars - 20B powered MX-5
  5. compete in a Hill Climb event and go to the track
i'll be happy if i can do the first 3 at least, hopefully :laugh:
Mine is to:
1. Win lotto
2. Buy my r34 Z-tune, wth lotto winnings.
3. Buy mansion
4. Go gym every second day. no need to work, as i win lotto.
5. Get with Salma Heyek, and Angelina Jolie at same time:P
That about covers it.
Edited by silverbulletR33
Mine is to:
1. Win lotto
3. Buy mansion
add those to my list as well :P
mines are:
1. get a girlfriend
2. lose weight
haha mad.
mine are.
1. Keep my new good/awesome job.
2. Get into this tafe stuff....cause uni was ghey and boring for me.
3. Spend my money wisely (may it be on car or not)
4. Keep in touch with my friends
5. Get a girlfriend, so i am not so bored, and maybe this one will like me....
(these are not in the right order..free dinner for the person who guesses the order [needs to be femaie, average build, about yay high, friendly, and like going for drives, males not included])
6. Spend money.....
7. Save money
8. Get fit again, cant say gain or loose weight cause that doesnt work.
9. If i get here then i better start again cause i missed something.
good points steph..
Friends are the people who keep you going. Me i am always looking to do something with my friends cause i am always bored....hey so if anyone else is bored out there let me know. :P
Mine is to:
1. Win lotto
3. Buy mansion
if u bought a mansion why would u bother going to the gym, wouldnt u already have one in your mansion, i know i would....
Hmmm resolution eh?
1. More money.
2. Wheels for car
3. 270 rwkws plus mark.
4. Women hmmm, would be good,
5. No smoke its bad.
6. To always be happy like every year.
7. This one should really be for everyone. (To be happy, have fun, and a very safe and prosporous New year for all )
:yes:
Adam
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
