hey guys,
After doing a few hoops i looked down to see that my speedo had died, so i contiuned to check if the cable was broken, the thing is i dont know because the inside of the cable is spinning but the little plastic thing was not attched to the cable, it was in the back of the speedo?
Does this mean its broken as im sure the little plastic needle comes attched with the cable.
any experiences?
Cheers
https://www.sau.com.au/forums/topic/148394-speedo-dead/
Yep very common. Plastic bit breaks off..
I beleive some places can fix them, after buying several new ones over the years I found out that it was possible :)
They are easy to remove, check around. A place that makes brake lines and cables here in NZ fixes them so try a similar place there.
GTS-T cables are normally not too expensive to buy, but there is no guarantee that it won't break again if it's second hand.
Edited by GTR-Ben
https://www.sau.com.au/forums/topic/148394-speedo-dead/#findComment-2770168
So my understanding is the the little plastic bit is suppose to be inside the speedo cable it self not in the back of the dash? is that correct?
Sigsputnik: if your speedo works i highly doubt the plastic thing has fallen as it is the mechanism that drives the speedo.
Edited by RaZ_TuRbO
https://www.sau.com.au/forums/topic/148394-speedo-dead/#findComment-2770897
hang on, what does this plastic needle look like? when i remove my dash, all i see on the speedo cable is, well, the square end of the speedo cable...has my plastic needle fallen off?
(the reason i as is that my speedo makes a clicking noise as i drive)
sigsputnik, thats the sound of a dodgy cable. it hasnt broken yet but possibily will soon. for a 32gtr they are only 100 new from nissan. fairly cheap for a gtr part :)
https://www.sau.com.au/forums/topic/148394-speedo-dead/#findComment-2770918
u need to remove the cable from the box, where it comes through the firewall is a couple of bolts on a plate, then u have to remove your speedo cluster and it pops out.
A place here in Adelaide actually can put a new steel end on the cable which should never break.
https://www.sau.com.au/forums/topic/148394-speedo-dead/#findComment-2771253
are you talking about the gearbox end or the speedo end?
https://www.sau.com.au/forums/topic/148394-speedo-dead/#findComment-2771276
They are talking about the Speedo end. There is a plastic part with a square end that turns the speedo. This has a spring etc and is attached to the cable. Replacing it with a metal end would be a good idea.. should be stronger from factory.
Maybe this will wear your plastic speedo though, who knows..
https://www.sau.com.au/forums/topic/148394-speedo-dead/#findComment-2771322
ah, good - so follow the cable from the speedo down? hmmm looks like i'll be in the cabin with a torch tomorrow :P
hope ur got plenty of time and patience. ull hafta remove the dash. the cable goes into the side of the gbox. good luck
https://www.sau.com.au/forums/topic/148394-speedo-dead/#findComment-2772973
guys i got the same prob. and its the second time.....first time it was the plastic piece that had split so it would lock on....i glued it together...put back it and it worked...now its F@#Kd again. So im assuming it the plastic piece again....
should i just buy this piece from nissan? wats it worth?
cheers boys
https://www.sau.com.au/forums/topic/148394-speedo-dead/#findComment-2790979
just went and bought a new speedo cable for 32 gtst. is it hard to replace? do i need to remove more than just the cluster to get it out? coz i looked down with a torch. i cant seem to see that plate. also where does it come out? down behind the clutch pedal? coz i saw a cable go out there sumwhere.
https://www.sau.com.au/forums/topic/148394-speedo-dead/#findComment-2792583
I am pretty sure it attaches to the gearbox, but I have no idea how or where, sorry - this is something i need to find out also. the manual doesn't seem to say, which is odd. how much did the cable cost?
https://www.sau.com.au/forums/topic/148394-speedo-dead/#findComment-2793663
  • 4 weeks later...
where in adelaide did you get this steel end??
https://www.sau.com.au/forums/topic/148394-speedo-dead/#findComment-2856489
mine breaks every time I go drifting,The rapid speed changes just breaks the glue loose.
I pull the speedo cluster out, put some araldite in the plastic thing where the spring lives, then some araldite on the square peg that goes into the speedo. Put the plastic thing into the housing, push it in so it's tight with a small screwdriver, then slide the speedo cluster back on.
Some people have had success with using heat shrink to close up the plastic....I didn;t have success. This way works, just has to get done every time I leave the track! haha
Takes me about 30 minutes to do now. I'll take photos next time if I remember,
https://www.sau.com.au/forums/topic/148394-speedo-dead/#findComment-2861176
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
