accident in the hills? that reminds me, when we went on the hill cruise i noticed a cefiro on jacks on the side of the rest point in the hills near corkscrew - u remember the one im talking bout sam where i was going to stop but couldnt.
lol, yeah, was funny, you wanted to stop but the trail of skylines behind you didn't :cheers:
I cant believe you didnt see the white AE86 in front of it
  • Replies 6k
Posted Images
nah i didnt was too bz trying to look down the side of the cliff where theirs enormous mining bobcats/trucks then spotted the cefiro. Man the corkscrew was fun particulary after hearing what rob - i think thats his name, had to do in his rwd gtr. rofl
scary stuff hay, i didnt catch the whole story, but didnt sound good
yeah he had major issues trying to take their 180 degree hairpin turns and the likes. we should do the same route again, but instead of heading back to adel via eagle on the hill. head straight to handorf from the pub at lobethol.
sounds good dooky, i really like that piece of road, well suited to skylines :cheers:
handles good? definately good for handbrake corner entries
Handles like poo, but hey you gotta use your imagination in these sorts of cars, wouldn't catch me rippin no handbrake in the 33 tho, my mate has but he's a full on slider, used to have a 31(as stated in drift battle being "the most drifted out 31 in Australia) but the damn fool has switched to a 180.
yeah but by looking at the respones to organised events ppl pull out at the last moment. ie dinner and cruise as a good example. so would be good just to get phone numbers and go say something like "want to crusie this afternoon" and make a decision straight away instead of yeah i'll go then later say nah i cant.
I also second that motion, and sometimes it's better with just 4 or 5 when it's like that!
my brothers 180 is set up for drift and when you pull the hand brake epsecially in this weather condition, you better know what you are doing cause the thing goes absolutely sideways. same cant be said bout the 33 though as i havent bothered trying.
But the Mt Lofty cruise was a good turnout, nice weather, no probs at all! I sort of need a bit of notice cos i got to drive 100ks to the meet up point :cheers:
Yeh my mates got a thing for ripping it heaps early like i mean heaps early, he wants to rip it at the canteen at Mallala for turn one, and has even gone as far as saying doin a 360 into slide turn one, but i said I'll appaude when i see that one!!
I dont think 33s are suited to full-on drifting, theyre more of a drivers car
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
