yep, either of you guys are most welcome to have my S15 in your garage .... I just need around $37k deposit :(
Nah it's not really nerve-racking waiting .... I am a bit excited about its arrival, but will be much more excited when it is actually here :D .... also I will be very sad when the S15 is sold, so I am not in any real hurry to sell it :D
  • Replies 6k
Posted Images
Damn, thats me out :D
Nah it's not really nerve-racking waiting .... I am a bit excited about its arrival, but will be much more excited when it is actually here :D .... also I will be very sad when the S15 is sold, so I am not in any real hurry to sell it :(
Yeah, i would imagine that you will miss the old PCOTY
We went to the Sea and Vines festival at McLaren Vale yesterday = damn hungover today!! (poor Chops was nominated driver).
We left home for the Vale yesterday morning at around 7:30am, then headed back to a mate's place at Sheidow Park afterwards to continue drinking, and we got home around 11pm - was a bloody long day.
I lost count of how many bottle of wine I drank .... and I might have had a little vomit around 2:30am this mornning too :D
:D sounds like you had fun. it's not weather you win or lose, its how drunk you get! lol, chops seems to get designated driver a lot
sam, of course its registered. It aint a dedicated drift car although it looks like one atm. I have funds now to make it look as good as it goes. finally.
maybe you should leave it how it is. put mis-matched rims on it, whack that vented bonnet back on, u know, stick with the whole drift theme :D
it would be too noticeable and stick out like a sore thumb to those who you dont want noticing it. Im might head down gillhams tomorrow and see what they have in terms of equipment.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
