  • Replies 6k
Posted Images
hey duc, yeah thanks man, im starting to feel better. I should be out working on my car, but im not allowed :D. I'm pretty sure my oil consumption prob is turbo related, so once i'm definate, im going new turbo. Did you say Guy (4 door sleeper) has a GCG hi-flow?
panel work and raising suspension. Theres a s14a front that i can get in the same colour as the the car - saves painting, but dont know if its worth it since the sil front would then be worthless parts afterwards.
I think the S14 has slightly different lines on the guards too, yeah, id stick with the S13 front, what price is on the s14 one?
Sorry for the late reply, I am having internet speed issues (I think its fixed now - spent the last 45 min on the phone with the help desk)
I have a GCG hi-flow on my 33.
(Since I am on broadband I sometimes leave to internet on even though I am not at the PC - sorry if this makes it look like I ignored you. )
Thats cool about the late reply :). I just wanna ask a couple of questions. How did you organise shipping your turbo to and from NSW? I've heard a lot of good things about this turbo, how have you found it so far?
Thanks,
sam
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
